92 civic w/ jdm gsr possible tps prob.
Hey guys i guys Like it says up top i got a 92 si hatch w/ a 94 jdm gsr motor. I got everything grounded and hooked up correctly, I also put a skunk 2 70mm throttle body and a blox intake mani on. Car idles fine, but when i get her goin and try and lay into the gas the motor just falls flat on its face. If you creep into the throttle the rpm will clime but only when u go to lay into it, it wont go. Could this be the tps, i never set it to 1/2 volt at closed throttle when i put it on but some people told me that it would not matter. ANY THEORIES
