lock problems PLEASE HELP
we were pullin into the drive way yesterday,..& my wife opened the door before the car got completely stopped,& i think she hit the lock buttom w/the doors open,..& now the automatic locks for the driverside does not work,..does anyone know how i can fix/reset this?
First check the fuse for the door lock switch, if the fuse is not burned then the next step is to replace the door lock actuators. My EP had the same problem, replaced both sides.
You saying the power lock switch for the driver's door doesnt work? Does the key fab lock and unlock the door(s)? If the key fab unlocks the doors and locks them correctly, then you need some diagnosis in the switch. If the key fab and door lock switch wont lock or unlock the driver's door, then you need to check for voltage at the driver's door lock actuator. Please dont waste money replacing parts as a diagnostic tool, it could prove costly.
MIBPreacher
Honda Civic (2001 - 2005)
Feb 3, 2013 04:38 PM
danb18c
Jan 20, 2008 05:49 AM
