RSX does not engage VTEC
Old Mar 3, 2007 | 12:58 AM
03RSXTypeS's Avatar
Default RSX does not engage VTEC
lost my license due to stupidity so my rsx-s has not been driven frequently for about 4 months now. I bumped my car to get let it idle for 15 min......when i reved the car it bounces at 5500. Any suggestions to a solution. thank you.
Old Mar 3, 2007 | 04:48 AM
Ironxcross's Avatar
Default Re: RSX does not engage VTEC (03RSXTypeS)
i hate when my VTAK doesn't engage.
Old Mar 3, 2007 | 08:09 AM
mikestypes's Avatar
Why would you want to engage Vtec when not in gear and not moving?
The ECU does not let you rev over 5500 when vehicle speed is not above 5 mph. It is perfectly normal.
Old Mar 3, 2007 | 11:33 AM
H Tuning's Avatar
Default Re: RSX does not engage VTEC (mikestypes)
Old Mar 3, 2007 | 05:34 PM
chrisguyver's Avatar
Default Re: RSX does not engage VTEC (H Tuning)
this is a stupid question but what is vtec and how does it work and will it work on 5 speed automatic.
Old Mar 3, 2007 | 05:54 PM
eMpAtHy's Avatar
Default Re: RSX does not engage VTEC (chrisguyver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisguyver &raquo;</TD></TR><TR><TD CLASS="quote">this is a stupid question but what is vtec and how does it work and will it work on 5 speed automatic. </TD></TR></TABLE>
http://en.wikipedia.org/wiki/VTEC
That site will explain to you what VTEC is.
If your car has vtec, then yes, it will engage. VTEC is basically the samething as ZTEC, VVTL, Zanos (although, the zanos system from BMW is more advanced as it dosent just have 1 set stage it goes to, but rather, the zanos system has a few). It just wont engage in neutral at a standstill.
Old Mar 3, 2007 | 07:10 PM
Default Re: RSX does not engage VTEC (eMpAtHy)
oh thanks makes more sense. how about this one so i have a automatic but its five speed can anyone tell me a little about that what the diffrence between the regular automatic and the maunal transmition. thanks for any info
Old Mar 4, 2007 | 05:29 AM
eff sea's Avatar
An automatic: you stick it in D, and press the "go" pedal. The car goes, like, with magic.
A manual: You clutch in, shift to first gear, roll onto the throttle while letting off the clutch, and THEN the car goes. When the revs get high again, you clutch in, and shift into 2nd gear, then third, and so on.
Old Mar 4, 2007 | 10:19 AM
Default Re: RSX does not engage VTEC (meimei)
yes but what does 5 speed auto mean is it the same as regular automatic trans
Old Mar 4, 2007 | 11:37 AM
danio's Avatar
you have 5 gears rather than 4..
Old Mar 4, 2007 | 11:46 AM
eMpAtHy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisguyver &raquo;</TD></TR><TR><TD CLASS="quote">yes but what does 5 speed auto mean is it the same as regular automatic trans</TD></TR></TABLE>
an automatic is an automatic. a manual, you have a clutch and normally move gears in and out yourself. There is also the paddles with a clutch that would technically constitute as a manual, but u normally see those in expensive cars.
They make automatics with a different number of gears. they used to make and use 3 gear automatics. You can find those in older cars and cars such as geo metro's. Currently, some cars have as many as 7 gears in automatics, but u will only usually find them in high-end luxury cars.
Old Mar 4, 2007 | 03:14 PM
MyK20Rips!'s Avatar
sounds like some people in hear need to study motor and transmissions for dummies, and not post **** like "what is vtec&gt;?"
Old Mar 4, 2007 | 11:22 PM
inkong's Avatar
the answer to the reason the rev doesnt pass 5.5 grams when stationary is stock two step ... your ecu is just trying to over do the engine and just cause youve idled it for 15 mins doesnt mean its warm ... anyway just be glad you have the two step ... most people buy that ...
Old Mar 5, 2007 | 12:47 AM
JCL's Avatar
JCL
Default Re: RSX does not engage VTEC (MyK20Rips!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyK20Rips! &raquo;</TD></TR><TR><TD CLASS="quote">sounds like some people in hear need to study motor and transmissions for dummies, and not post **** like "what is vtec&gt;?"</TD></TR></TABLE>
wicked krx
Jan 24, 2009 03:02 AM
badbeast
Jul 16, 2006 09:45 PM
93FastLs
Mar 25, 2005 12:24 PM
NA JDM GSR
10
Mar 24, 2005 02:06 PM
hookedonvtec
Jul 6, 2004 11:27 AM
