Wet my Distributor
Old Mar 2, 2007 | 09:45 PM
JDM_EK4_Coupe's Avatar
(banned)
Default Wet my Distributor
I has my hood up and it started to pour, my dizzy got wet and now it beging to bog whenever I am in 4th and 5th. Now my question is, would the whole distributor itself be damaged or could it just be the cap. Im not a tech on Distributors and I would just like someone to help me out on this.
Old Mar 2, 2007 | 09:46 PM
1fastek702's Avatar
I've got my distributor wet before and had no issues. are you sure that no water went into your intake manifold.
Old Mar 2, 2007 | 09:48 PM
kreative's Avatar
Default Re: Wet my Distributor (JDM_EK4_Coupe)
did you check the inside of the cap? how does it look?
(banned)
Default Re: (1fastek702)
Yea, pretty sure. How could water get in there?
Old Mar 2, 2007 | 09:49 PM
(banned)
Default Re: (JDM_EK4_Coupe)
What would a bad cap look like? it looks fine to me. Its funny though because it is ONLY in 4th and 5th that the bogging occurs
Old Mar 2, 2007 | 09:56 PM
A.E Motoring's Avatar
i went through a car wash one time, and i have my hood proped up, it never gave me a problem before, but this last time, ******* car wouldnt start and the fuel pump wouldnt prime, lucky it started and i just kept it running, but fuel pump wouldnt prime., so finally it starting priming again and the car would start, i turned it off, and unplug the plugs to the dizzy and a **** load of water just came out, so be careful, trying changing out the cap and rotor
Modified by Dual Cam Racing at 11:34 PM 3/2/2007
Old Mar 2, 2007 | 10:00 PM
(banned)
Default Re: (Dual Cam Racing)
thanks guys, im going to give it a try tomorrow
Old Mar 2, 2007 | 10:13 PM
solerizr's Avatar
check your spark plug tubes as well. I got water in there once too, messed it all up.
Old Mar 2, 2007 | 10:21 PM
(banned)
Default Re: (solerizr)
Thanks for the support guys, I double checked my cap and saw some dust in it so im assuming thats bad.
Patrick Tobar
Jul 16, 2017 08:34 AM
go2sleep
May 4, 2007 07:19 PM
h23vtec_dc2
Feb 1, 2004 02:09 PM
girlieracerk
Dec 18, 2003 10:12 PM
atli126
Oct 19, 2003 11:16 PM
