itr brakes vs wilwood
Old Mar 2, 2007 | 07:06 PM
batboyvaj's Avatar
Default itr brakes vs wilwood
How do the itr brakes compare to the wilwood kit that fits under 15" wheels?
Old Mar 2, 2007 | 07:15 PM
neo_'s Avatar
Default Re: itr brakes vs wilwood (batboyvaj)
Is there a reason you are in need to upgrade your calipers? Some good pads and fluid go a long way on stock ITR calipers.
Old Mar 2, 2007 | 07:19 PM
batboyvaj's Avatar
I'm building a new track car and debating which would be better to go with. Also waging if the wilwoods are worth the extra cash. The setup will be a 300 hp turbo delsol.
NorthernXposure's Avatar
Default Re: itr brakes vs wilwood (neo_)
he asked what the differences were in braking capabilities between the two... not how to upgrade his oem pads and lines
Old Mar 2, 2007 | 07:23 PM
Big Phat R's Avatar
ITR calipers are cast, single piston, use OEM or Type R spec aftermarket pads and 23 mm OEM rotors (one piece) ---> cheap to maintain
Wilwood Dynalites are forged, four piston, use Wilwood HP pads, and one or two piece rotors --> expensive to maintain
The braking on a Type R is TIRE LIMITED usually - so upgrading your brakes mainly saves you unsprung weight, improves fade resistance and improves modulation.
Old Mar 2, 2007 | 07:30 PM
batboyvaj's Avatar
do the wilwoods offer much "more" braking power? I figure I would go with the itr brakes because of maint. costs.
Old Mar 3, 2007 | 07:07 AM
FullRaceHonda's Avatar
Default Re: (batboyvaj)
i dont think you can really get much more breaking power than itr brakes, but you can get better modulation, im planning on nsx calipers
Old Mar 3, 2007 | 01:34 PM
neo_'s Avatar
Default Re: itr brakes vs wilwood (NorthernXposure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorthernXposure &raquo;</TD></TR><TR><TD CLASS="quote">he asked what the differences were in braking capabilities between the two... not how to upgrade his oem pads and lines </TD></TR></TABLE>
So why didn't you answer his question then?
P.S. I never said anything about lines.
jryKC
Suspension & Brakes
Mar 19, 2016 06:21 AM
dan12288
33
Feb 8, 2011 12:27 PM
EFRue57
Sep 20, 2008 06:22 PM
Andy_B
Oct 1, 2002 07:42 AM
Incognito
Jan 3, 2002 10:15 PM
