Treadstone Turbo Kit?
Old Mar 2, 2007 | 03:42 PM
GSROWNSU's Avatar
Default Treadstone Turbo Kit?
Ok guys be completely honest with this one...is this kit good or not? So far i have almost everything i need as far as management and fuel setup for my turbo build...now i have to decide on what i want to do about the actual turbo setup (manifold, wastegate, turbo, bov, ic and charge pipes) This kit by treadstone performance features a turbonetics turbo and wastegate. Comes with everything i have left to buy for my build. If this isn't worth the money and you think i should find something else can you please give me an idea on what i should be looking for? It's going on my gsr and i am hoping to make around 250 whp on 7-8 lbs of boost (daily driver) Here's the link
http://www.treadstoneperforman...years
Old Mar 2, 2007 | 03:57 PM
BoostedEG6's Avatar
Default Re: Treadstone Turbo Kit? (GSROWNSU)
looks like a decent kit for the price
Old Mar 2, 2007 | 04:01 PM
DfwBB6's Avatar
Default Re: Treadstone Turbo Kit? (BoostedEG6)
looks very similar to another company or the vecco kit
Old Mar 2, 2007 | 04:24 PM
non-VTEC's Avatar
those are all pretty good components that come with that kit.........not a bad price at all..
Old Mar 2, 2007 | 04:37 PM
GSROWNSU's Avatar
so you guys think i should go with that kit? Do you think the t3/t4 will give me a decent spool and some good numbers as well? With this kit i will have everything i need then. I already have hondata, injectors, fuel pump, and a wideband so i'll be good to go
Old Mar 2, 2007 | 05:12 PM
uberhaulin's Avatar
i know there intercoolers are very good a few friends of mine have them and i will be purchasing one for spring
Old Mar 2, 2007 | 05:21 PM
BoostedEG6's Avatar
Default Re: (GSROWNSU)
I say go for it
Old Mar 2, 2007 | 05:26 PM
t0ng0's Avatar
Im buying one of those kits on monday but before i do theres four choices of turbo that they let you pick
V trim stage 2 .48
H trim stage 2 .63
60-1 trim stage 3 .63
60-1 trim stage 5 .63
i don't know which one to pick...
i was reading about a guy that bought one of this kit and did 12,s in the quarter...
Old Mar 2, 2007 | 05:54 PM
integra3586's Avatar
Default Re: (t0ng0)
the only flaw i see it the wastegate placement, it is gonna boost creep
Old Mar 2, 2007 | 05:59 PM
sohcturbohatch9's Avatar
Default Re: (integra3586)
boost creep i hava drag manif and wg the same way no problems 10 psi girl!
Old Mar 2, 2007 | 08:41 PM
GSROWNSU's Avatar
Default Re: (t0ng0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ng0 &raquo;</TD></TR><TR><TD CLASS="quote">Im buying one of those kits on monday but before i do theres four choices of turbo that they let you pick
V trim stage 2 .48
H trim stage 2 .63
i was reading about a guy that bought one of this kit and did 12,s in the quarter...</TD></TR></TABLE>
I would also like to know the answer to this. I know what the .63 and .48 are...the area to radius ratio. I will definately go with a .63 size turbo but what is the difference between a stage 3 and a stage 5 turbo? Also what is the difference between an h trim and a 1 trim??
Old Mar 2, 2007 | 08:48 PM
Default Re: (sohcturbohatch9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcturbohatch9 &raquo;</TD></TR><TR><TD CLASS="quote">boost creep i hava drag manif and wg the same way no problems 10 psi girl!</TD></TR></TABLE>
cool, you're lucky
Old Mar 4, 2007 | 01:28 AM
integra racr04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSROWNSU &raquo;</TD></TR><TR><TD CLASS="quote">
I would also like to know the answer to this. I know what the .63 and .48 are...the area to radius ratio. I will definately go with a .63 size turbo but what is the difference between a stage 3 and a stage 5 turbo? Also what is the difference between an h trim and a 1 trim??</TD></TR></TABLE>
+ 1...
Old Mar 4, 2007 | 10:08 AM
da_dude's Avatar
60-1 stage 5 with the .63 a/r FTW. I believe stage 5 have a bigger turbine wheel which give you less back pressure then the stage 3. You know turbo hate back pressure. Don't quote me on it though.
Old Mar 4, 2007 | 10:13 AM
GSROWNSU's Avatar
what about the other trim turbos they allow you to choose from? What is the difference between them? As previously stated i know the difference in a/r ratios but not the different trims or stages.
Old Mar 6, 2007 | 02:42 PM
GSROWNSU's Avatar
bump
Old Mar 6, 2007 | 02:44 PM
anyone??
Old Mar 6, 2007 | 05:06 PM
94civic18's Avatar
Default Re: (integra racr04)
experienced user of this kit, found out the guy was actually born a 10 minutes away. Good guy to deal with, RECOMMEND NOT using filter supplied with kit, because a metal piece got sucked in and DESTROYED the turbo, but they replaced it for free! HIGHLY RECOMMENED but PLEASE save yourself the troubles and buy a decent air filter.
Old Mar 6, 2007 | 05:43 PM
93supercoupe's Avatar
Default Re: (94civic18)
i just donnu about that mani, it looks good, but the WG flange is njot in the right spot.
Old Mar 8, 2007 | 07:07 AM
94civic18's Avatar
Default Re: (93supercoupe)
wastegate is in a fine location. Just may have to customize your dumptube a little bit. Also make sure you dont crossthread on that manifold.
Old Mar 8, 2007 | 10:28 AM
Azn Kenny's Avatar
Is it a/c friendly and will it fit a GSR in an EG?
Old Mar 8, 2007 | 11:30 AM
T25So's Avatar
Kinda O.T.- but im using a treadstone intercooler on a turbo miata running a t3/60-1@ 12 psi, and street tuning the haltech showed an over 20 degrees drop under ambient of the air at the t.b......so I givethem a
Old Mar 8, 2007 | 01:59 PM
slodel's Avatar
Default Re: (T25So)
there is one on ebay looks identical
for cheaper too
Old Mar 8, 2007 | 02:11 PM
LSVTECTURBO-EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">looks like a decent kit for the price</TD></TR></TABLE>
Old Mar 8, 2007 | 03:57 PM
gritsak's Avatar
Default Re: Treadstone Turbo Kit? (LSVTECTURBO-EG)
isn't treadstone the name of the organization in the bourne movies
