Slave cylinder ?
Old Mar 2, 2007 | 03:33 PM
hondachris1994's Avatar
Default Slave cylinder ?
Im about to change my slave cylinder...whats the bar thing for in the pic... http://i46.photobucket.com/alb...6.jpg
Old Mar 2, 2007 | 03:34 PM
and what does the rubber thing with the small hole part go to?
Old Mar 2, 2007 | 03:47 PM
92_VX_EG's Avatar
Default Re: (hondachris1994)
What kind of car and year do you have? You name leads me to think a 94 civic but I've never seen a slave cylinder that looks like that before.
Old Mar 2, 2007 | 03:48 PM
its a cx
Old Mar 2, 2007 | 03:53 PM
mhohenlohe's Avatar
the metal rod fits into the boot on the left facing the way they do in the pic, then the boot slips on the top of the cylinder, the round part of the rod will touch against the pressure plate arm
Old Mar 2, 2007 | 03:54 PM
92_VX_EG's Avatar
I just realized that it does look like the usual slave cylinder. It's just not fully assembled. You have to put it together. The last one I bought came assembled. By looking at it... you should be able to figure it out how it goes. Remember to bleed it after you put it on.
Old Mar 2, 2007 | 03:55 PM
DrewMD's Avatar
Davis Photography
Default Re: (mhohenlohe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mhohenlohe &raquo;</TD></TR><TR><TD CLASS="quote">the metal rod fits into the boot on the left facing the way they do in the pic, then the boot slips on the top of the cylinder, the round part of the rod will touch against the pressure plate arm</TD></TR></TABLE>
correctimundo
Old Mar 2, 2007 | 04:04 PM
I had to use the old bar cause the new 1 was different look..... http://i46.photobucket.com/alb...9.jpg
that will b ok rt?
Old Mar 2, 2007 | 04:09 PM
mhohenlohe's Avatar
should be, but ive never seen that end on one before, just make sure the rods diameters are the same between the old and new one
Old Mar 2, 2007 | 04:12 PM
I have a b16 and when I bought the car it has a cable tranny, so they might have prefabbed that bar to make it work
Old Mar 2, 2007 | 04:18 PM
bmoua's Avatar
its sort of like a piston...it works back and forth when you press and depress on the clutch
Old Mar 2, 2007 | 06:49 PM
how much brake fluid does it take 2 bleed it?
Old Mar 2, 2007 | 08:57 PM
92_VX_EG's Avatar
Just bleed it until it feels good. It might take a little brake fluid. Bleed it until it lets a steady stream of brake fluid out with no air. good luck
Old Mar 3, 2007 | 03:48 AM
It doesbt help that im tryin to bleed the clutch bymyself, its just not workin for me
Old Mar 3, 2007 | 05:42 AM
U do leave the clutch master cap off when bleeding correct? Or does it even matter?
Old Mar 8, 2007 | 11:21 PM
vi3tromanc3r's Avatar
i left mine open to see if the fluid was going down or not, because you dont want it to go all the way down that way it will suck up air and u'll have to start over. but dam i just relized that my slave cylinder is fucked, cause it makes a sqeaky sound when i step on the clutch, and the rubber boot that covers it is ripped. you know where i can get another one for my 95 civic si. and how to put it on and all since, it seems like youve already done it.
ThatOneOG
Jun 10, 2008 03:18 PM
Jay Dirt
Oct 26, 2007 05:27 PM
mugenspoongsr
Aug 3, 2006 11:41 AM
LSEGHATCH
Jun 11, 2006 11:04 AM
