I NEED HELP ON A 2005 ACCORD ASAP!!!!!!!
Old Mar 2, 2007 | 02:48 PM
aristo808's Avatar
Default I NEED HELP ON A 2005 ACCORD ASAP!!!!!!!
hey folks,i really need help on this.me and my boy had bought a 2005 honda accord that was smashed.we had fix everything on the car.well now i had run a scan tool on the car since it has a check engine light on and i had a couple of codes that showed up!i have had:
idle air control
shift solinoid stuck open
we haved replace the idle air control and the idle is still jumps up and down.we also tried cleaning it the throttle body and it's still runs the same.what else i need to check.
also i need to know how do i have to replace the shift solinoid?is this solinoid in the trans?not sure were it's lacated at?is it easy to change?let me know need this car to run cherry,really want to drive it....thanx
Old Mar 2, 2007 | 06:14 PM
Intense3.2's Avatar
Default Re: I NEED HELP ON A 2005 ACCORD ASAP!!!!!!! (aristo808)
Make sure all the vacume hoses are connected properly & dont have any leaks. Also, try re-seting the ecu. As fas as the solenoid. . I have no idea.
surelyjersey
Aug 27, 2014 06:50 PM
xilef1025
Jan 10, 2012 07:40 AM
rcjordan5749
Jul 16, 2007 11:37 AM
rayk5799
Jan 6, 2006 04:04 PM
aws140
Aug 26, 2005 07:51 PM
