changing my tranny fluid today...need advice {searched}
i heard alot of good reviews about honda MTF and GM synchromesh but i don't know what to put...and i don't know where to get the synchromesh
im leaning towards the synchromesh.
my question is...where can i find the synchromesh and how much do i put
You also could just use regular engine oil 10w-30w. Ive used it in both my GSRs. I dont know where you could get any of the other Oils but your GSR tranny holds about 2.2 quarts. Just fill it till it starts to come back out of the fill hole.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg »</TD></TR><TR><TD CLASS="quote">You also could just use regular engine oil 10w-30w. Ive used it in both my GSRs. I dont know where you could get any of the other Oils but your GSR tranny holds about 2.2 quarts. Just fill it till it starts to come back out of the fill hole.</TD></TR></TABLE>
ive heard of that before to put motor oil...but i'll just be on the safe side and put what honda entended to put in there
I believe that you have to get the GM Synchromesh from a GM dealer, just like you would get the Honda MTF at a Honda dealer.
The manuals, (for most hondas, if not all), say to use 10w30 or honda MTF.
Many people use GM Synchromesh as a band-aid type fix for worn synchros.
They are both about tranny fluids.
https://honda-tech.com/zerothread?id=965397 –
https://honda-tech.com/zerothread?id=999135 –
If Honda Manual Transmission Fluid is not available, you may use an API service SG, SH, or SJ grade oil with viscosity of SAE 10w-30 or 10w-40 as a temporary replacement. However, motor oil does not contain the proper additives and continued use can cause stiffer shifting.
dammit i dont know what to buy anymore...but ive been hearing better reviews for the GM synchromesh...what about the "friction modified"??
is it the same?...and also heard that it's not good if it's too thick
WTF!!!...im changing the oil tonight but dont know what to get
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr »</TD></TR><TR><TD CLASS="quote">dammit i dont know what to buy anymore...but ive been hearing better reviews for the GM synchromesh...what about the "friction modified"??
Youve got to be kidding me. You have over 2000 post....SEARCH. Fluid topics have been BEATEN TO DEATH. Every fuking day there is another fluid thread. If you have a grind use the syncromesh....if you want to mix it with regular 10w30/10w40 that is fine. If you want to mix it with honda MTF that is also fine. If you dont have anygrinds, i would just put in 10w30, 10w40, or honda MTF. THEY WILL ALL WORK. This isnt rocket scientist. I use 10w30 oil and i have no fluid related problems.
</TD></TR></TABLE>Youve got to be kidding me. You have over 2000 post....SEARCH. Fluid topics have been BEATEN TO DEATH. Every fuking day there is another fluid thread. If you have a grind use the syncromesh....if you want to mix it with regular 10w30/10w40 that is fine. If you want to mix it with honda MTF that is also fine. If you dont have anygrinds, i would just put in 10w30, 10w40, or honda MTF. THEY WILL ALL WORK. This isnt rocket scientist. I use 10w30 oil and i have no fluid related problems.
guilty as charged i use syncromesh as a bandaid for my worn syncros but it works great my tranny feels awsome. I have friends that use is in there cars to and say it works awsome.
for syncromesh
for syncromesh
i wound't bother using the gm or gm with friction modifier. it's like 10.00+ a quart and i found that not all gm dealers have it instock. don't get me wrong it works wonders if you have a mild case of grinding syncros. this is coming from someone who used it, but if your tranny peforms perfectly fine i would stick with hond mtf, and if that's not available 10w30 works to.
i have a slight 3rd gear grind on high rpm's....and yes ive searched but everytime i go to a thread it seems that it contredicts to what the other thread says....so im confused now, but i guess im making up my mind and going with the synchromesh because of grind
so i removed the old oil and it was still good, it was not black or anything and the draing plug was clean, no metal dust at all.
i went with the GM synchromesh friction modified....i was expecting more but i guess im satisfied, no 3rd gear grind anymore
shifting is still alittle hard, i though it was going be like when the car is off and you play with the gears, like that soft...but whatever
are you supposed to feel the difference right away?...or do you have to wait a couple miles?...
shifting is still alittle hard, i though it was going be like when the car is off and you play with the gears, like that soft...but whateverare you supposed to feel the difference right away?...or do you have to wait a couple miles?...
1JDMDOMINICAN
Sep 23, 2005 12:38 PM
xd69
Jun 18, 2005 10:51 AM
