95 Ls swap into 95 CX hatch What kinda problems or NONE???
Old May 21, 2002 | 07:20 PM
95cx's Avatar
Default 95 Ls swap into 95 CX hatch What kinda problems or NONE???
Ok well I just boguht a 95 LS complete swap. I'm putting it in friday night. I know most everyhting is bolt in adn plug and play but will i have any problems taht are real common??? Any codes??? 5 spd cx to 5spd LS?????
Or shoudl i be good to go in a night
Old May 22, 2002 | 02:22 AM
SoulSurfer's Avatar
Default Re: 95 Ls swap into 95 CX hatch What kinda problems or NONE??? (95cx)
LS throttle cable is too long so you're going to need the throttle cable out of maybe a 92 LS? I think that's what cable you need but Im not sure. Otherwise, everything worked great for my 95 LS into my 92 CX.
Old May 22, 2002 | 03:22 AM
95cx's Avatar
Default Re: 95 Ls swap into 95 CX hatch What kinda problems or NONE??? (LSCivicHB)
ok cool cause we are swappping it at the junkyard casue they got big lifts there so i will just make a dash to the yard and grab me a throttle cable. Thjanks for the info.
Old May 22, 2002 | 06:20 AM
95cx's Avatar
Is that going to be my only problem I will confront??
Old May 22, 2002 | 09:07 AM
Jayson S.'s Avatar
When I did the swap on my buddy's 93 hatch we reused the Civic throttle cable. You just have to make your own throttle cable bracket.
Another thing that nobody mentioned.........you will need an EG Si exhaust system to make it all match up underneath. You can also get aftermarket exhausts but the Civic Si Catback will bolt in very easily making it a simple swap.
Jayson S.
Old May 22, 2002 | 12:05 PM
95cx's Avatar
Default Re: 95 Ls swap into 95 CX hatch What kinda problems or NONE??? (Jayson S.)
ok cool, were just going to weld the exhust flange to the correct place.
DC206R
May 6, 2010 09:53 AM
bori bori
Dec 27, 2009 01:25 PM
rice a roni
Apr 30, 2004 02:34 PM
DavidTurbo
Apr 14, 2003 05:41 AM
widecoupe
Oct 2, 2001 07:54 AM
