What's the difference when installing this motor in My crx??
Hi all, Was wondering if anybody could give me some pointer's or suggestion's on this motor..http://www.hmotorsonline.com/shop/sc...age&item=30020
Anyway, i herd from somebody that it is different then the usdm Si motor?..espeacially when you do the install??..I have a 1990 crx SI with a blown motor...Im going to pull it out this weekend and clean the car up..After that i want to order this motor from Hmotorsonline and attempt to put it in my crx si...I will not be ordering the zc trans for extra..I want to re-use the usdm si tranny..Is it possible?? any other wiring that i need to know??..Any help would be greatly appreciated..Sorry, but im new to the motorswap..thanx
88-91 SOHC ZC longblock
Price: $ 395.00 Plus shipping and handling.
Availability: In Stock
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
- 5 Speed ZC Transmission(Add $150)
- Motors
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
- Motors
that engine is basically the same as your Si engine, but has 118hp - will bolt right into your car the same as if it were another Si engine - just put your engine wiring harness on the ZC and you are good to go
why not go with the dohc zc .. 20 more hp and it still just plugs in. only about 150 more.
edit: never mind.. their sold out.
The dohc zc is a great motor, but I'd stick with the sohc for more aftermarket/swap support. Unless your spraying, or going boost with zc dohc, then your just a badass
Thanx for all the info peepz!..Ya, Im going with the sohc for now because that's all I can afford..Just want to get the car running and it will still be fun..
On the ZC dohc motor I thought you had to add lik3 3-4 wires for the second cam or something?? i don't think it's a direct plug & start with si harmess..But thanx for the recommedation..
I believe at least the distributor plug is different for the DOHC ZC.
http://rywire.com/store/dohc-d...bf51e
Yeah...That's what it was...****,.I can make my own wiring for free!...tHOugh, THE $35 is way convinient for a lazy %8#@@@ like me!....lol
all you have to do is connect the distributor wires up.. depin the plug.. take the two cam sensor wires and add a little bit of wire on them and connect the wires to the cam sensor.. not too hard.
srebik
Jun 4, 2004 12:24 PM
ArchAngel Sabastian
Sep 23, 2001 08:18 AM
