4WD Wagon Suspension
Old Mar 1, 2007 | 08:54 PM
KBG Indey's Avatar
Default 4WD Wagon Suspension
My friend is looking to replace the suspension on his 88 4wd wagon, and we don't know if the rear strut set up is different from that of a 2wd one, should any suspension that fits a typical ef also fit the 4wd wagon?
Old Mar 1, 2007 | 09:07 PM
danmdevries's Avatar
Default Re: 4WD Wagon Suspension (KBG Indey)
Nope, regular EF suspension bits usually are advertised/sold with "(except wagon)" after the description.
Old Mar 1, 2007 | 09:41 PM
1fastek702's Avatar
All ef suspension is the same all models.
Old Mar 2, 2007 | 11:48 AM
KBG Indey's Avatar
ok so thats kinda contradicting, anyone else? =\
Old Mar 2, 2007 | 12:00 PM
SHUTTLE's Avatar
goto http://www.hondacivicwagon.com
they are different form all other EF chassies i should know i have 1 with a modified suspension
AllMotoRex's Avatar
Default Re: (KBG Indey)
I would think its different ..i have a crx and a wagon .. the wagon is 2600 lbs compared to 2100 to my crx , you would think it'd need to be stiffer for the wagon since its heavier ..but again i'm not sure just guessing.
Old Mar 2, 2007 | 12:33 PM
KBG Indey's Avatar
Default Re: (SHUTTLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHUTTLE &raquo;</TD></TR><TR><TD CLASS="quote">goto http://www.hondacivicwagon.com
they are different form all other EF chassies i should know i have 1 with a modified suspension</TD></TR></TABLE>
thanks for the link very helpful
Old Mar 2, 2007 | 01:53 PM
Cvic90's Avatar
the upper and lower controls arms are the same, depending on the year. the spring heights and rates are different though. Get adjustable coilovers and crx or hatch shocks. Thats what I did to my brothers. That way you can get the height right. Don't even try to put stock rear discs on it unless your good at metal fab either. that **** sucked bad. I spent 12 hours cutting and bracing and getting it to fit his 2WD. The front is the same as any other civic. I need to put his car up for sale actually.
Old Mar 2, 2007 | 03:18 PM
extra cam needed's Avatar
From: americas finest, calee fourn ya, united states
Default Re: (Cvic90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cvic90 &raquo;</TD></TR><TR><TD CLASS="quote">the upper and lower controls arms are the same, depending on the year. the spring heights and rates are different though. Get adjustable coilovers and crx or hatch shocks. Thats what I did to my brothers. That way you can get the height right. Don't even try to put stock rear discs on it unless your good at metal fab either. that **** sucked bad. I spent 12 hours cutting and bracing and getting it to fit his 2WD. The front is the same as any other civic. I need to put his car up for sale actually.</TD></TR></TABLE> Could you give more info on the stock rear disc problem?!
Old Mar 2, 2007 | 03:24 PM
SHUTTLE's Avatar
go to http://www.hondacivicwagon.com its been covered
Old Mar 2, 2007 | 03:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHUTTLE &raquo;</TD></TR><TR><TD CLASS="quote">go to http://www.hondacivicwagon.com its been covered</TD></TR></TABLE> Yea! I just have to find my password again so I can log on and chat.
Old Mar 9, 2007 | 07:26 PM
Akiraboy's Avatar
Default Re: (extra cam needed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extra cam needed &raquo;</TD></TR><TR><TD CLASS="quote"> Yea! I just have to find my password again so I can log on and chat.</TD></TR></TABLE>
pm me your info if you haven't resolved this & I'll reset it.
Its easier to use civic/crx rear struts. Is it correct? Probably not but I'm usin them w/o probs.
sorry, only pics I could find right now
my wagon on EF tokico blues & non adjustable Tein springs
kiddef9
Jun 22, 2010 07:14 AM
Tyson
Jun 26, 2006 11:08 AM
