B20- 98 Civic Coupe, mounting issue!
Old Mar 1, 2007 | 08:48 PM
Jay.D.Em!'s Avatar
Default B20- 98 Civic Coupe, mounting issue!
Some guy gets a B20b swap done by a regular oil lube mechanic, and he cant drive 1 inch without popping his axles, he brings the car to my job, and what do you know? none of his motor mounts are bolted in! th eguy also put a rubber exhaust hanger between the bracket and mount on the tranny.. idk why, anywho, we realigned the motor and got all the mounts in there properly, but the rear mount bracket is giving us trouble, i think he had the stock automatic b20b rear mount bracket on there, and we tried a so called "si" bracket, but it was too long so we figured it was D series.. what bracket is best??? i hear SI, or GSR should work fine, but i wanna know before i start looking... thanks!
Old Mar 1, 2007 | 09:00 PM
Eran's Avatar
HT White Ops
Here's the brackets you need:
99-00 Civic Si rear tranny mount
96-00 D-series tranny torque mount
96-00 D-series front torque mount
B20Z timing belt mount (two-bolt to hook up to the stock d-series mount on the subframe)
Old Mar 2, 2007 | 10:30 AM
Jay.D.Em!'s Avatar
Default Re: (Eran)
Bump???????
Old Mar 2, 2007 | 10:51 AM
pdiggitydogg's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Here's the brackets you need:
B20Z timing belt mount (two-bolt to hook up to the stock d-series mount on the subframe)</TD></TR></TABLE>
This is correct
But you can also use the em1 timing-side-block mount
Old Mar 2, 2007 | 11:10 AM
Eran's Avatar
HT White Ops
Default Re: (Jay.D.Em!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay.D.Em! &raquo;</TD></TR><TR><TD CLASS="quote">Bump???????</TD></TR></TABLE>
I love when people bump when they've already been given the answer they asked for. It's a nice way of saying "I don't believe you. You're lying to me."
Old Mar 2, 2007 | 11:12 AM
Sloshy's Avatar
well its always best to get a second opinion theres ppl that dont really know what they're talking about..
Old Mar 2, 2007 | 11:15 AM
Eran's Avatar
HT White Ops
Default Re: (hatch-E-vanish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish &raquo;</TD></TR><TR><TD CLASS="quote">well its always best to get a second opinion theres ppl that dont really know what they're talking about..</TD></TR></TABLE>
"Thanks for the reply, anyone else care to confirm?" works pretty well
Old Mar 2, 2007 | 11:26 AM
Sloshy's Avatar
here what you need 99-00 civic SI rear bracket and driver side bracket (mounts to block) and your stock civic rubber mounts will work
Old Mar 2, 2007 | 04:50 PM
do now theyve been told the same thing 3 times.....
Old Mar 2, 2007 | 10:27 PM
Jay.D.Em!'s Avatar
Default Re: (pdiggitydogg)
ok well i tried si, ls, b20, and gsr rear mount brackets and none of them are working, so im gonna have th eguy bring me a different mount. since he didnt know which one was which i had to go by rule of elimination but when the si one didnt fit i knew there was a problem with the mount itself.. freakin ebay mounts, ughhh.
-and thanks for being a *****, i bumped because i wanted multiple opinions.
Old Mar 2, 2007 | 10:32 PM
Eran's Avatar
HT White Ops
There is no reason a 99-00 Si rear mount shouldn't work. It's a 96-00 B-series tranny rear mount.
Old Mar 4, 2007 | 08:20 AM
Jay.D.Em!'s Avatar
Default Re: (Eran)
im thinkin this guy got a fuckedup ebay mount kit or somethin, cuz now he doesnt know what mount is what, or what bracket is what, everyone is tellin hom somethin different, i guess thats what u get when u pay someone 200 to do a swap.. ill be hackin away on monday
gsr_b20x2
Aug 2, 2005 06:48 AM
EJCivJdM93
Feb 9, 2005 04:40 AM
b20ek
Jun 28, 2003 12:40 PM
jcivic
Feb 11, 2003 07:56 PM
delacampos
Jan 27, 2003 06:22 AM
