Dino test adjustment
does anybody know were i can get my integg dyno test & adjusted around San bernardino county or LA County in cali. it doesnt feel like its running right i have a b16, with type r cams skunk 2 mani aem adjustible cams excedy stage 2 clutch & modified ignition coil also p30 ecu
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZ90DATEG »</TD></TR><TR><TD CLASS="quote">look in the phonebook , call around</TD></TR></TABLE>
^^^That's like playing Russian Roulette with your motor (assuming that you go to the first one you come across).
https://honda-tech.com/zerothread/1347699 <--Read about references shops and choose one you feel is most qualified in your area.
RealStreet
Honda S2000
23
May 26, 2011 05:36 PM
