another car wont start post...
Old Mar 1, 2007 | 06:42 PM
authentic plusONErandy's Avatar
Default another car wont start post...
IM NOT GETTING SPARK
i checked out the archives thread..it didnt work
it seems as if im not getting spark (i pulled the wire out and cranked to check already)
fuel primes
timing belt is still intact
fuses are all checked
the dizzy is fine (i used my dizzy to start another car, and used another dizzy on my car, same results)
ecu is fine (i used another ecu to try to start up, still nothing)
main relay also good
starter is good
battery is good
Modified by plusONErandy dotdotdot k at 2:17 PM 3/8/2007
Old Mar 1, 2007 | 07:00 PM
dwigman's Avatar
Default Re: another car wont start post... (plusONErandy dotdotdot k)
what motor are you running? cause it could be the distributer
Old Mar 1, 2007 | 07:43 PM
Default Re: another car wont start post... (dwigman)
itr with odb1 dizzy.. how can it be the distributor if i used my distributor on another car and it started that car up... and when i tried another distributor on mine it didnt work either
Old Mar 1, 2007 | 07:49 PM
ATS*Mark's Avatar
OG triple OG
try a main relay and an ecu yet?
Old Mar 1, 2007 | 07:52 PM
Default Re: another car wont start post... (ATS*Mark)
yes both.. checked already
Old Mar 1, 2007 | 07:59 PM
asiandoood's Avatar
must be the official week for our cars to break down
i just told mark this afternoon the same situation i had.
Old Mar 1, 2007 | 08:23 PM
ATS*EK24's Avatar
Fresh start for 09'
Default Re: another car wont start post... (asiandoood)
damn still didnt find the problem??
**** so ecu, dizy and main relay not the problem ehh??
hmmmmmmmmm
Old Mar 1, 2007 | 08:29 PM
senoj's Avatar
Default Re: another car wont start post... (ATS*EK20)
try checking fuses.
Old Mar 1, 2007 | 09:39 PM
DsR_andy's Avatar
Default Re: another car wont start post... (senoj)
u check all your grounds?
Old Mar 1, 2007 | 11:55 PM
gsp ej1-em1's Avatar
Default Re: another car wont start post... (DsrXandy)
maybe your harness is messed up. something probably ripped under all that tape and loom.
Old Mar 2, 2007 | 02:43 PM
im out of ideas.... everything has been checked, harness seems okay (all voltage passing), grounds checked...what else?!?!?!
Old Mar 2, 2007 | 03:13 PM
Default Re: (plusONErandy dotdotdot k)
check that one plug that goes on the end of the harness. it looks liek a dead plug. its on the driver side next to the clutch master cylinder.
Old Mar 4, 2007 | 05:30 PM
checked still no go
Old Mar 4, 2007 | 05:33 PM
ATS*Mark's Avatar
OG triple OG
this may be a stupid question but do you know for sure your not getting spark?
Old Mar 4, 2007 | 05:37 PM
Bense's Avatar
what ecu
Old Mar 4, 2007 | 07:05 PM
Default Re: (ATS*Mark)
well we pulled the plug wires to check..no spark
p28 ecu and also tried a jdm b16 ecu both nothing
Old Mar 4, 2007 | 07:16 PM
ATS*Mark's Avatar
OG triple OG
the plug wires , you hooked a spark plug to it right.......
Old Mar 4, 2007 | 08:07 PM
S2K2000's Avatar
Hmmm... did you try replacing the coil wire?
Old Mar 4, 2007 | 08:27 PM
Default Re: (S2K2000)
Old Mar 4, 2007 | 08:59 PM
JACER63's Avatar
try checking the harness where it plugs in dizzy maybe problem there.im stumped ohter than that.. good luck
Old Mar 4, 2007 | 11:56 PM
SkyliteCustomz's Avatar
check the AGC fuse
Old Mar 5, 2007 | 12:01 AM
B18CivicEH2's Avatar
Default Re: (SkyliteCP)
maybe this can help you..
http://techauto.te.funpic.org/ignition.php
good luck
Old Mar 8, 2007 | 01:16 PM
up for no luck
Old Mar 9, 2007 | 04:00 AM
HondaWrench's Avatar
What is the voltage on the coil positive (+) during cranking?
What is the voltage on the coil positive (+) and negative (-) during cranking?
Can you hear your injectors clicking during cranking?
Is this the type of distributor with the coil inside? Therefore, did you check the spark in there?
Does the check engine light come on then go out normally?
Modified by HondaWrench at 6:55 AM 3/9/2007
Old Mar 9, 2007 | 04:41 AM
hatchy69's Avatar
Default Re: (HondaWrench)
Same exact shyt is goin on wit my boys 96 coupe, no spark, take off the distributer cap and see if the rotor spins wen u try to turn the car on, if it doesn't it maybe the cam that's what a friend of mine told my friend it was cuz I guess wen the cam spins it makes the spark in the distributer then spreads it thru the wires to the plugs to the motor. Anyways the cam gear spun but the cam didn't maddd wierd but see if the rotor spins wen u take off the cap
