LM-1 digital air/fuel ratio meter
Old Mar 1, 2007 | 05:45 PM
smcowman's Avatar
Default LM-1 digital air/fuel ratio meter
Does anyone know if this thing works? and how? i mean i want to set my A/F ratio back to where it should be and i dont understand how this thing does it or if it even does...any help is appreciated
Old Mar 1, 2007 | 06:16 PM
thewrai6th's Avatar
Default Re: LM-1 digital air/fuel ratio meter (smcowman)
I have one, PM me.
It does have a narrowband output, but it is programmable.
Old Mar 1, 2007 | 07:25 PM
doood's Avatar
been there done that
Default Re: LM-1 digital air/fuel ratio meter (thewrai6th)
all it does is tell you accurately what your afr is. it doesnt adjust it. you some sort of ems for that.
Old Mar 1, 2007 | 08:47 PM
Rikter's Avatar
What doood said.
All the LM-1 is good for is telling you the reading of your air fuel mixture. It is not plugged into the ecu or able to make corrections/tune your car. You need other stuff for that.
-Rik
Old Mar 1, 2007 | 10:01 PM
thewrai6th's Avatar
The narrowband output is programmable, so is the wideband output. They can both be setup for wideband (0-5V), or both be setup for narrowband (0-1V). So if you don't have it setup right, your car will get the wrong readings and run rich or lean to compensate.
You can tell it that 7 AFR is 0V, or you can say 10 AFR is 0V, or you can say 15 AFR is 0V.
RTFM
Old Mar 1, 2007 | 10:08 PM
thewrai6th's Avatar
Default Re: (thewrai6th)
http://www.innovatemotorsports...l.pdf
cetv
Feb 14, 2006 02:06 PM
Benjithx
Jan 13, 2005 10:08 AM
ZCHF
Mar 1, 2003 03:20 PM
Turbohatch
Dec 15, 2001 12:21 PM
