trottle booty =p
a friend of mine gave me an EX trottle body and i was wondering if i should change it out my HX for it..would it do anithing performance wise?
Modified by krazyhmongboi at 6:49 PM 3/1/2007
do you know the mm of the hx? i know the ex throttle body is 56mm. if its smaller than that yes you will get more hp and throttle responce. make sure you port match the throttle body to the intake manifold. what motor do you have?
portmatch just means you match the intake minfold with the throttle body. take a dremel with a side grinding stone (not sand paper) and slowly grind away at it untill the port on the intake manifold is the same size as the throttle body. thats it then just bolt it up. make sure every things going to switch over though, tps an map
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazyhmongboi »</TD></TR><TR><TD CLASS="quote">o0o makes sense.whats a good way to do it to not get shavings inside? </TD></TR></TABLE>
stuff a bunch of paper towls in it, then after that pull them out and wash it out with hot water and soap if you want to. just make sure you get all soap film out of it. let it completly dry berfore you put it back on
n8dizzel
Jan 23, 2008 04:14 PM
