Replacing alternator
Old May 21, 2002 | 06:16 PM
b18b98's Avatar
Default Replacing alternator
How hard is it to replace an alternator on a 90 accord. Its located in the front (i think ). Is it as easy as unbolting it and bolting on the new one? Is there a trick on how to remove the belt and pulley? How much does an alternator go for? Thanks in advanced.
Old May 21, 2002 | 06:59 PM
Padronis's Avatar
Default Re: Replacing alternator (b18b98)
One thing buy a Honda alternator. It took me 3 aftermarket alternators before I got one that didn't die in a week. If it is anything like my teg, it is a maze to get it in and out. loosen the bolts and the belt should slip off, your new alternator comes with a pulley. My suggestion would be to look at your car and see which way would be the easiest to take it out. Aftermarket was $95, Honda will be more, but very well worth it. Inspect your belt, it probably needs to be changed.
oldghost
Oct 14, 2018 11:39 AM
mjrino
Feb 18, 2007 08:31 AM
dhn
Mar 25, 2006 08:48 AM
