took head off, now putting it back on
Old Mar 1, 2007 | 03:57 PM
MotorSpecies ver1.6's Avatar
From: MoonSHINE Metropolis, .FL. Run Free, North America
Default took head off, now putting it back on
hello.............Is it neccesary to clean the heads combustion chambers of the usual carbon deposit(cant i simply put the head back on)?? I took the head off to install valve springs and retainers. will loose particals interfere with the piston rings or get burnt/blown out via engine cycle ????????????
Thanks
Old Mar 1, 2007 | 04:14 PM
Mr. Carbon Fiber's Avatar
Default Re: took head off, now putting it back on (MotorSpecies ver1.6)
Did you forget to install new valve stem seals also? I would clean everything while it is off and even check the surface for possible warpage. Resuface the head and have it clean (hot tank?) if u have down time. Hope this helps!
Old Mar 1, 2007 | 04:21 PM
quadnie's Avatar
if you take it to the machine shop for resurfacing you'll pay $20-40 and will include a quick hot tank. That's usually what I do.
Old Mar 1, 2007 | 04:45 PM
Default Re: (quadnie)
tru truu. I installed new valve seals aswell. warpage was within spec(no need for resurfacing). Im going to clean it. my thoughts are is it possible to simply put it back on without cleaning the chambers(and expect previous similar running condtions) ; and if not cleaned, will loose particals interfere with the piston rings or get burnt/blown out via engine cycle ????????????reason being i might have to re-assemble this motor sooner than expected(buddies motor).
understand what i mean??
thanks
Old Mar 1, 2007 | 05:04 PM
Default Re: (MotorSpecies ver1.6)
Ok, then I guess just spray it down with brakes/parts cleaner and blow dry with air gun and i should be fine!
ehrkeith
May 7, 2012 05:17 PM
StraightNoChaser
May 23, 2008 01:32 PM
A2_8U
Dec 7, 2007 03:45 AM
SVOboy
19
Jun 22, 2006 05:30 PM
