93lude vtec; oil light came on, then engine died with a smell?
when the oil light was flashing. i checked the oil dip stick and it showed full. sometimes it'll stop flashing and then it'll flash again. I kept on checkin the oil and it's still good. So i ignore it and then after driving it for 100 miles, engine dies on me on the highway with a wierd smell. what is wrong? my engine blown?
I agree your pump probably died... light came no because there was low pressure... and you just killed your engine from oil starvation. But hopefully you had better luck than that and it's not totally screwed up. I'd say you're gonna need new bearings though.
engine is toast, crank journals are probably mashed;
need bearings, and your camshafts are probably powder.
it didn't throw a check engine at any time during this?
rebuild or new motor time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikesta21 »</TD></TR><TR><TD CLASS="quote">damn! so if your oil light goes on.. and it is due to pump failure.. should you stop the car and tow! how long does it take to damage the engine, or does the starvation occur instantly?</TD></TR></TABLE>
you can pin point it easily. make sure theres enough oil in the engine.
if its low, add oil and see if the light goes off. if its full and the light stays on then get it towed.
the check light engine doesnt seen to appear after engine went out. When i turn key to on, check engine light doesnt show. dang so i'm gon need a new engine. whats the best advice to do now? thanks
not necessarily. the oil light just means low pressure. it could be a pump or the oil is so low that the pump isnt pumping anything. but in hoeboy's case, its the pump
i would check by putting a mechanical gauge on and seeing forsure what the pressure is and then go from there. just for ***** and giggles it could be just a flaky sensor or bad connection
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">i would check by putting a mechanical gauge on and seeing forsure what the pressure is and then go from there. just for ***** and giggles it could be just a flaky sensor or bad connection</TD></TR></TABLE>
what do you mean by that?
100 miles seems a little long to go with out a pump???you didnt here any knocking sound??what happens when you try to start it know? in any case if it is the pump you will need new crank ,,bearings possible rods unless salvageable cams and rockers minimum.
Hey OP--
Any chance you had an Unorthodox underdrive pulley or something like that? It's a little unusual for an oil pump to die, wondering if there was some other cause..
yeah before it dies, i heard some loud knocking from the valve cover. yea i'm just going to throw that egine away. go for jdm h22a. any thing i should know before swapping a jdm h22a? different wires, connector, converson?
LShatchie
42
Sep 29, 2005 05:38 PM
d0nkeyxPunch
Jan 6, 2002 11:53 PM
It's very likely trash.
