something a bit new....Fnonvtec-Dtrans/EF chassis...my ongoing build
Old Mar 1, 2007 | 09:58 AM
redzcstandardhatch's Avatar
something different
Default something a bit new....Fnonvtec-Dtrans/EF chassis...my ongoing build
well, i have a big thread in EF section, but thought i'd post a more updated/smaller/all the relavant pics thread here, where it fits well. its very different, and should be a lot of fun. used to have a 300+ whp d16a6 (stock head, ran low 12's with traction issues).. some pics found out a failed injector (clogged a bit with some residue, now i'm going to drop the tank/run new fuel line, etc) caused the D to blow. it was flowing 30-40% less than the others..and i was pushing the engine on pump gas to begin with. luckily i had it tuned rich/conservatively.
now, some carnage photos!
MilkShake anyone???
MilkShake valve cover..
Poor Mister Sleeve.
Poor Mister Piston
new/old rare DRAG wheels..havent found any other sets
cage mod pic, raised it up, painted it...its not padded too.
Old Mar 1, 2007 | 10:03 AM
something different
pic of the nice 80K f22a1 i bought for cheap.. its SO clean underneath it freaks me out. gonna rip it apart, clean the head more, new valve seals, deck it, new HG, ARP head studs (already have all that stuff) and putting some BISImoto valve springs in it. its also getting a custom WEBcam designed by bisimoto for me. obviously using the bisimoto adaptor kit.
Old Mar 1, 2007 | 10:08 AM
something different
Default Re: (redzcstandardhatch)
some pics of the partial progress of the mount..its really strong, and i boxed everything, should be great... using the Kaizenspeed balance shaft eliminator kit, so i'll have a bit more clearance, but i notched it out a bunch so its easy to work on, etc. the welds will be seam-sealer'd over, and all painted. should be fun.
Old Mar 1, 2007 | 10:13 AM
something different
Intake manifold runners welded up...minor porting/polishing was required inside, nothing terrible..next is making a plate for them, using my brothers CNC machine.. it will have velocity stacks incorporated in it, etc..lots of machine work.
also shows the 90 mm q45 throttle body (modified, cut off all the useless nissan stuff i'm not using)... the nissan TPS works with honda's too..kinda neat
Old Mar 1, 2007 | 10:15 AM
something different
covered my aluminum shifter-carptet-hole-filling piece i made.
i'm excited..should go great with the black/white lettering on the corbeaus, and be just weird enough for me
thanks for the inspiration hybridkoop
Old Mar 1, 2007 | 10:16 AM
something different
plates for splitimes and my plenum/velocity stack manifold parts just came in.. they are huge. gonna be a LOT machining going on w/ the cnc machine
i'm kinda proud of my front mount i built/modded traction bar. the welds arent super pretty, but its all hidden with the rad hose/fan/downpipe/wastegate anyways.. it turned out fairly well. should be UBER strong...and it adds quite a bit of stiffness to the whole setup
web cam came ..thanks bisi...hope it works well. its a custom turbo grind he had done...says it should idle well, and make great power. i guess thats the idea!
waiting for 2 more things...the freaking crank pulley, and the freaking exhaust flange..
Old Mar 1, 2007 | 10:19 AM
something different
compared to a stock SI, untouched. you can see how much i've moved the frame. spent quite a while figuring out where to start, what needs strength, and how to make it strong. its burly
Old Mar 1, 2007 | 07:16 PM
Crimson_Tide's Avatar
Default Re: something a bit new....Fnonvtec-Dtrans/EF chassis...my ongoing build (redzcstandardhatch)
wow a lot of work and it all looks beautiful... cant wait to get back to the states and build another ef... fab work over here is extremely expensive... im going to start working on my welding skills a little bit to get me through my time in japan... not a lot of work that i can do on a suby though... btw do you have a link to your old sleeper thread? thanks a lot and keep up the good work... that things going to be a beast
-Josh
Old Mar 1, 2007 | 07:45 PM
something different
the old sleeper? i think you mean my good buddy luke (red civic standard)
thanks man!
Old Mar 1, 2007 | 08:17 PM
oops my bad lol
Old Mar 2, 2007 | 05:17 AM
something different
you'd be surprised how much people get luke and i mixed up.. i guess are names and cars are similar. hehe
he and i are building another car together for the grassroots motorsports 2007$ challenge (88 hf, ghetto LS boosted, should go real fast)
you'll see more from us together
Old Mar 2, 2007 | 11:09 AM
MR.johnson's Avatar
i miss my boosted F civic.
Old Mar 2, 2007 | 03:26 PM
something different
Default Re: (MR.johnson)
dont see many civics with F swaps! cool
Old Mar 2, 2007 | 11:21 PM
143MYVTECEF's Avatar
Interesting.. more progress?
Old Mar 3, 2007 | 04:57 AM
something different
Default Re: (143MYVTECEF)
more progress shots early next week..got a big trade show all weekend thats taking up 100% of my time.. ick.
heatshield intake mani gasket and injectors came in, and the crank pulley is on its way..
Old Mar 5, 2007 | 05:45 AM
SOHCD16y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">you'd be surprised how much people get luke and i mixed up.. i guess are names and cars are similar. hehe
you'll see more from us together</TD></TR></TABLE>
I dont know what you guys are planning on doing for fuel/tuning. But Adam and I are going to be putting his bone stock LS on the dyno with E85 and are going to try and break 340 (current record) with it next week. If if all works out we would be happy to do the same on the grassroots car.
Old Mar 5, 2007 | 10:15 AM
something different
Default Re: (SOHCD16y8)
we're using DSM 450s... and pushing them as far as they go...only real cheap injector option for us. only 2007 bucks to spend.
we're street tuning on chrome...maybe borrowing a G meter..if it helps (probably wont help)
i'd love to have your input on the tuning though..its gonna be a bigger turbo, but should spool well, and have a great lil' poweband.
BTW..the new program for the CNC machine came today..hopefully my brother hooks it up ASAP..and we can make some manifolds.. WOOT
Old Mar 5, 2007 | 10:43 AM
SOHCD16y8's Avatar
Well the 450's pretty much throw the E85 right out the window.
What turbo are you running on it, it should be a good lil motor with lots of torque.
I would be more then happy to help with the tune for you guys.
Old Mar 5, 2007 | 11:36 AM
something different
t3/t4 from a big drag setup..to4b , etc... bigger hot side...i've only seen pics (its sitting in the car in my backyard though, just havent touched it yet)
Old Mar 5, 2007 | 08:43 PM
something different
thanks for the pics kyle!
collector/flange all welded up.. seamsealed the mount today.. pulley=here in a day or two according to UPS.. flange=should be here soon i hope
Old Mar 5, 2007 | 09:11 PM
high_revs's Avatar
Old Mar 6, 2007 | 04:16 AM
SOHCD16y8's Avatar
Are you actually planning on mounting the turbo in that fashion? If so that is exactly how I was trying to describe to kyle to tell your brother what I wanted made eventually.
Old Mar 6, 2007 | 04:58 AM
something different
i'd love to. but no.
thats the Banks turbo for our 99 superduty diesel..haha
Old Mar 6, 2007 | 05:01 AM
something different
man, i'm so happy with how my brother's welds are looking... He loves the new water-cooled torch..it works so much better..
Old Mar 6, 2007 | 08:48 AM
SOHCD16y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">i'd love to. but no.
thats the Banks turbo for our 99 superduty diesel..haha</TD></TR></TABLE>
Haha yeah I figured that, but i wasnt sure if the t3/t4 was going in like that.
I really hope in the future (maybe this summer even) to make a manifold that will mount my Sc60 (and Gt35 when I get it) up front like that with him. His Fab skills are absolutely amazing.
