FS: d16z6 SOHC Built motor, sleeved block, race type head, turbo parts - Lots of pictures, no 56k he
Will only be selling this as a COMPLETE package deal (unless offers for individual parts are REALLY good). All parts are BRAND NEW, 0 miles, never installed in a car unless marked used.
What's included:
Block:
-d16z6 AEBS Sleeved block, raw sleeves - need to be bored and honed.
-Eagle H-beam connecting rods with ARP 2000 Rod bolts
-Wiseco 75.5mm 8.5:1 Compression coated pistons
-ARP Head studs and bolts kit
Head:
-d16z6 Head (already assembled), has competition 5-angle valve job, ported, new Supertech valvetrain (valves, guides, springs, titanium retainers, seals), Comp/Zex Cam 59300, Unorthodox Racing 5 bolt adjustable cam gear, Polished VTEC valve cover.
-Skunk2 Intake manifold ported to match the head and bored to 68-69mm for the throttle body.
-BDL 70mm throttle body
-STR Competition fuel rail
-1000cc RC fuel injectors
-Hondata IM gasket
-New valve cover gasket set
-GM or Motorola 3 bar MAP sensor or Motorola 2.5 bar MAP sensor, your choice!
Turbo Parts:
-Garrett T3/T04E (was told .60 trim .63 a/r when I ordered it; intake housing shows .60 a/r exhaust housing shows MI .63) Part #466159-5004 Model #TA3405 - $600 SOLD
-3" Stainless 4 bolt downpipe to match exhaust housing - $125
-P.I.T. External Wastegate with 3 springs (I believe 7psi, 11.7psi, and 14psi) - slightly used - $150
-Ramhorn manifold with external wastegate flange and ceramic coated. Looks crappy, works excellent! Black marks are due to being ran with no gaskets between parts. -used for ~5,000 miles on friends car - $550
-Stage 4 XTD clutch kit with HD pressure plate: rated to 500hp SOLD
Pictures are in order of how they are listed above
Bottom end:
Head and parts:
Turbo Parts:
If you are wanting other parts, I also have:
JKMotorsports Traction bar - only mounted on shell
Konig Heliums 15" bronze with Falken Azenis 205/50/15 - BRAND NEW!
Modified by b18_ef_hatch at 12:33 PM 3/24/2007
What's included:
Block:
Head:
-Hondata IM gasket
Turbo Parts:
Bottom end:
Head and parts:
Turbo Parts:
Thanks man
Make REASONABLE offers on parts of set up or complete.
Prices are as follows:
Everything under "block" was $2,200
Everything under "head" was $3,500
Everything under "turbo parts" was $1,500
Complete investment is $7,200 (
WAY MORE than I thought)
Will sell the ENTIRE set up for $6,000 or you can make offers on what you want
As for the other parts:
Traction bar $225/offer
SkunkWorks $best offer by this weekend
Konig Heliums w/ Azenis $Will only sell if I get close to what I paid retail
WAY MORE than I thought)Will sell the ENTIRE set up for $6,000 or you can make offers on what you want
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95turbodteg »</TD></TR><TR><TD CLASS="quote">1500 for bottom end? how much for skunks?</TD></TR></TABLE>
I can do the block for that. The rods and pistons alone were over 1/2 that.
Skunks I just had a local offer for $100 that I'm waiting to get finalized. If you can do that I'll let you know if it falls through.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">PM me let me know what you want for the rail</TD></TR></TABLE>
I'm not going to seperate the fuel rail, sorry.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPMvulocity »</TD></TR><TR><TD CLASS="quote">Y are you selling it. How much are you sell the skunk2 intake manifold?</TD></TR></TABLE>
I'm in school and don't work. Plus I got really sick and have over $4,000 in medical bills, so I have no money to finish getting the block done.
Skunk2 IM I don't want to part due to the port matching with the head and throttle body.
when u say u dont have time to finish getting hte block done, what else is left on it? does it come with crank and caps? or is it just the block/pistons/rods? does it have acl bearing in it or anything else"?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95turbodteg »</TD></TR><TR><TD CLASS="quote">when u say u dont have time to finish getting hte block done, what else is left on it? does it come with crank and caps? or is it just the block/pistons/rods? does it have acl bearing in it or anything else"?</TD></TR></TABLE>
I don't have the money to finish it. It is the block, rods, and pistons. I can include most or all of the parts under the oil pan for a few dollars, but will not be including a crank. It is stuck in the old motor and we have tried virtually everything to get the bolt out - WD-40, hitting it with a punch, pry bar, 600ft/lb impact gun. If you pick it up locally you can take the parts block for free.
Keep in mind if you are not able to pick up shipping will be a little spendy!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prototype2 »</TD></TR><TR><TD CLASS="quote">how much for the clutch? for d series?</TD></TR></TABLE>
Ummm, yes it is for a d-series. Make me an offer, I wasn't planning on parting that seperate as it was bought to be used with this motor set up.
who made the ram-horn? How much also? Can you get pictures of the collector?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENetics1 »</TD></TR><TR><TD CLASS="quote">who made the ram-horn? How much also? Can you get pictures of the collector?</TD></TR></TABLE>
I just asked my friend that I bought it from; waiting for his reply. Make me an offer...and don't lowball please. I can get pictures of the collector, what's your email address?
Ok, it was bought from H-T user kabaroo (who is a good seller) and he got it from Turbo-Elements.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowPokeEg »</TD></TR><TR><TD CLASS="quote">Bump for a great package and just about everyone hoping you'd part it out
Thanks for the bump! I've even had phone calls asking to part it out, but guys....that's not likely to happen unless you throw me some crazy good offers
I'm already losing over $1000 on the package deal so if I part it out it'll be even more than that and not worth me doing it.
</TD></TR></TABLE>Thanks for the bump! I've even had phone calls asking to part it out, but guys....that's not likely to happen unless you throw me some crazy good offers
my email is KEN-etics1@hotmail.com
Is that just some diy coating or was it professionally coated? also you got the dumptube?
Sent you a pm on offer for manifold and downpipe
Ceramic coating done by Boost Factory! I never had a dumptube made, so no dumptube.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swipe’d »</TD></TR><TR><TD CLASS="quote">bump 4 nice parts...let me kno when u wana part! </TD></TR></TABLE>
What parts were you wanting? I have some parts pending right now since they are easily replaceable in the set up. I will update if those sell so everyone can see what's missing from the above list.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">bump </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 hatch »</TD></TR><TR><TD CLASS="quote">wow ryan sorry to here your selling your project!! bump </TD></TR></TABLE>
Thanks for the bump guys
Depending on what sells and how serious some of the people are that PM'd me, I may keep what I don't sell and when my financial situation gets back to being ok I will start with what I have and do it again
Turbo, ramhorn mani, and downpipe are pending.
Edit: No longer pending, back up for sale due to a flaking buyer.
Modified by b18_ef_hatch at 7:18 PM 3/5/2007
