Mini-Me help...
Old Mar 1, 2007 | 09:02 AM
triton302's Avatar
Default Mini-Me help...
hi, i have a 99 civic dx sedan with the d16y7. i recently had a mini-me done to a d16y8. but... i've run into some issues. since i have the stock y7 block with y8 head, vtec, intake manifold, and p2p ecu, i've been getting different codes. after a diagnostics check i'm getting 2 codes, for the non-existant knock sensor and a torque converter circuit malfunction, since it's a stinking automatic. the reason why im keeping the automatic tranny is because i dont have the money to swap it out with an EX auto or do a manual swap, so im keeping this one for now. AND... when i put the p2e computer back in, i get codes for system running too rich and a fuel trim malfunction code. i seriously need some advice on what to do. Should i get the knock sensor installed on the block and out an ex torque converter in the stock tranny? or should i keep the p2e and put the old y7 fuel injectors back in and run vtec manually? any and all help would be great, thanks!
Old Mar 1, 2007 | 09:24 AM
Jonknee's Avatar
Default Re: Mini-Me help... (triton302)
with the p2p i think you're also gonna get a code for o2 sensor since i think it has to run two sensors. I would just run it obd1 p28 with conversion harness if u want to avoid knock sensors and another oxygen sensor, it might also get rid of the torque converter problem * does it have those two stupid solenoids on top of the tranny?*..
Old Mar 1, 2007 | 09:29 AM
triton302's Avatar
Default Re: Mini-Me help... (Jonknee)
i have both the 02 sensors, i just had them replaced because the went out. but the y7 tranny does have those two soleniods on the top of it.
Old Mar 2, 2007 | 08:48 AM
triton302's Avatar
just an update, the p2p ecu i had in the car was for a manual tranny and thats what gave me the TCC code, i got an auto p2p ecu and gave it a try and the only code i got was for the knock sensor which im putting in next week. if anyone can give me a clue as to how to wire it up that would be great.
Bleakened
Sep 28, 2015 12:01 PM
john'sD16Aek
15
May 1, 2013 02:25 PM
Civiclx
55
Oct 13, 2003 10:59 AM
