would the y8 timeing belt work for a mini me swap with a y8 head and a d16y7 block
You gotta give people more then 10 mins to respond, and if you cant wait then you should just search and go through the how tos.
Use the y8 timing belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">You gotta give people more then 10 mins to respond, and if you cant wait then you should just search and go through the how tos.
Use the y8 timing belt. </TD></TR></TABLE>
My understanding was to always use the head gasket and timing belt from the block you were using.
At least that is how it goes on the B-series. Not sure on d's.
friggen idiot, the y8 timing belt is hte same **** as the g7 because the same camshaft sprokcets and honda sucks
For B series LS/VTEC it goes off whatever water pump you use. For the 96-00 D series its all the same between engines, and for 92-95 i believe its water pump as well (not 100% sure but 85% sure)
byrne_06
10
Aug 3, 2010 12:56 PM
blinger
Jul 22, 2007 04:33 PM
lohatch
Jun 15, 2004 07:44 AM
Boosthead
Aug 12, 2003 06:17 PM
thanks tho.
