dc5 type-r wheels
Old Mar 1, 2007 | 07:29 AM
hondc5's Avatar
Default dc5 type-r wheels
hey guys i need help big time i just put my dc5 type-r wheel yesterday but i had to take the back one back off because it wass rubbing with the frame if anybody have them on let me know what have to do so it wont happen if i need any wheel spacer or anything thanks
Old Mar 1, 2007 | 07:41 AM
Todd00's Avatar
I said I don't want a title!
Default Re: dc5 type-r wheels (hondc5)
Did you not do the research before you bought the wheels?
Old Mar 1, 2007 | 07:53 AM
hondc5's Avatar
Default Re: dc5 type-r wheels (Todd00)
no men because i seen a couple pll with them already so i though it was no big deal u know anything about that
Old Mar 1, 2007 | 09:23 AM
SD-DC5's Avatar
Did you get any spacers with the wheels? Also, learn how to write sentences.
Old Mar 1, 2007 | 07:17 PM
swollen_cu's Avatar
Default Re: dc5 type-r wheels (SD-DC5)
you need spacers to put those wheels on a USDM rsx.
Old Mar 1, 2007 | 08:27 PM
danio's Avatar
It shouldn't rub without the spacers on the car. It'll just look funny with the wheels really tucked in.
Anyways, the correct spacer I believe is 15mm for the USDM RSX's.
Old Mar 2, 2007 | 05:04 AM
Todd00's Avatar
Default Re: (danio)
A 15mm spacer really needs extended lug bolts too for everything to be safe. 15mm is a considerable amount.
Research pays off.
Old Mar 2, 2007 | 10:33 AM
s2k_3.11's Avatar
Default Re: (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">A 15mm spacer really needs extended lug bolts too for everything to be safe. 15mm is a considerable amount.
Research pays off.</TD></TR></TABLE>
Is that all you're gonna tell him? research, research...
The rims should fit properly, as in they shouldn't rub.
With the 15mm spacers (H&R is what a lot of people have) you'll have zero problems.
My friend did that, worked out fine, now he's got the brembo conversion with the suspension too, so the spacers aren't needed anymore.
Spacers are more or less $60 for good ones.
Old Mar 2, 2007 | 10:56 AM
Todd00's Avatar
Default Re: (s2k_3.11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2k_3.11 &raquo;</TD></TR><TR><TD CLASS="quote">
Spacers are more or less $60 for good ones.</TD></TR></TABLE>
With 15mm spacers, how many turns of an OEM lugnut does he get before it seats?
Again, 15mm spacers are a considerable amount.
I'm not going to tell him anymore because putting such a large spacer on could be dangerous. Just because someone does it does not mean it is safe.
Old Mar 2, 2007 | 01:05 PM
s2k_3.11's Avatar
I'm not going to tell him anymore because putting such a large spacer on could be dangerous. Just because someone does it does not mean it is safe.</TD></TR></TABLE>
I know what you mean, but that's what it takes.
And people have been doing this for years, if it wans't safe something would have happened by now. (Just an assumption)
Also, the BEST thing to do, is the WHOLE conversion, brakes, suspension, sway bar and wheels. Then you have nothing to worry about
Old Mar 3, 2007 | 07:46 PM
BarracksSi's Avatar
Offset on the USDM RSX (base and Type-S; and the EP3, for that matter) is +45. The offset for the DC5-R is +60.
People run the DC5-R wheels for two reasons: style, and as the best fitting rim over the DC5-R Brembo brakes.
Personally, I'd go the whole way and use them with the brake conversion.
Old Mar 4, 2007 | 01:03 PM
eMpAtHy's Avatar
Also, the BEST thing to do, is the WHOLE conversion, brakes, suspension, sway bar and wheels. Then you have nothing to worry about </TD></TR></TABLE>
just because things have been used for years does not mean it is safe. Asbestos for example. Hydrogenated oil is another.
Old Jan 3, 2008 | 12:33 PM
Marlin07's Avatar
Okay so I bought the DC5R wheels and I know I need spacers before I bought the wheels...but I am having a hard time trying to find H&R 15mm spacers. They don't have to be H&R spacers thats just what I prefer. Can anyone help me out? Thanks in advance!
Old Jan 3, 2008 | 07:28 PM
GradyDC5's Avatar
I have kics 25 mm spacers. It's perfectly flush.
Old Jan 3, 2008 | 09:29 PM
02bluteg's Avatar
You dont NEED spacers but they sit much better with them.
And you definitely dont need extended studs with them at all, Im not sure why someone said you do.
Get some H&R 25mm spacers, they will fit great and have a sexy stance. You wont be disappointed.
Old Jan 4, 2008 | 08:04 AM
Marlin07's Avatar
Default Re: (02bluteg)
Damn that does look nice! I know I dont need them I just what to sit flush. I cant find any I need some help with that. Where did you get your 25mm spacers at GradyDC5?
Old Jan 7, 2008 | 03:32 PM
Marlin07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BarracksSi &raquo;</TD></TR><TR><TD CLASS="quote">Offset on the USDM RSX (base and Type-S; and the EP3, for that matter) is +45. The offset for the DC5-R is +60.
That would mean you would have to have 15mm spacers to have your car have the Type R stance.....Why would you get 25mm?
Old Jan 8, 2008 | 09:16 PM
jdmjin's Avatar
Default Re: (Marlin07)
i shaved a lil off the lower control arm and it fits with no problem....
ive had the wheels for about a year now and theres no problem....
Old Jan 8, 2008 | 09:41 PM
JCL's Avatar
JCL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marlin07 &raquo;</TD></TR><TR><TD CLASS="quote">
That would mean you would have to have 15mm spacers to have your car have the Type R stance.....Why would you get 25mm?</TD></TR></TABLE>
why not? to have the more "aggressive" look....?
Old Jan 8, 2008 | 11:10 PM
NTCustoms's Avatar
you don't need to have 25mm spacers, 15mm is fine...really i wouldn't do it for an "aggressive" look because you really wouldn't be aggressive running 17x7 anyways...it just causes more stress on the wheel bearings.
Old Jan 11, 2008 | 04:27 AM
Mr. Dc5's Avatar
Default Re: (NTCustoms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms &raquo;</TD></TR><TR><TD CLASS="quote">you don't need to have 25mm spacers, 15mm is fine...really i wouldn't do it for an "aggressive" look because you really wouldn't be aggressive running 17x7 anyways...it just causes more stress on the wheel bearings.</TD></TR></TABLE>
Damn NT you on here too lol
Old Jan 11, 2008 | 06:18 PM
NTCustoms's Avatar
i'm everywhere foo
Old Jan 11, 2008 | 08:28 PM
Mr. Dc5's Avatar
lol...helping anyone with their fogs on here???
Old Jan 17, 2008 | 09:46 AM
SpEeDyX's Avatar
Default Re: (Mr. Dc5)
Man everytime i read this thread i get more confused. First you should get 15 mm spacers but according to todd they kill oem lug nuts and shouldnt get spacers at least 15mm cause thats too much. So that would mean get extended lugs right? Then others say get 25 mm spacers...im confused. Maybe its best just to buy the whole suspension off jdmland.com that includes the rims for a lil ova 3k(very expensive though and rather not have to when i look to buy these rims)
Old Jan 17, 2008 | 09:57 AM
Marlin07's Avatar
Default Re: (SpEeDyX)
The offset for the type r is +60, the usdm rsx is +45 making a difference of 15. I am buying the H&R DRS 15mm spacers. They come with extended lugs.
