gsr cable tranny in crx, no speedometer
I can pull the mechanical (cable) VSS out, put the speedometer cable in it and spin it with a drill and my speedometer works. Put it back in the tranny and no speedometer. You can feel the vss slide into place so I think its lined up. You can spin the wheels with the vss out, the frontend jacked up and the car in gear and you can't see or feel anything moving to drive the cable. Is this something broken inside the tranny that can easily be replaced/repaired?
ef9civicgen4
May 29, 2008 03:26 AM
1SIKCRX
Jul 14, 2004 10:52 PM
