Tire Size Question, pls help
Old Feb 28, 2007 | 11:59 PM
spoonem2's Avatar
Default Tire Size Question, pls help
oky, i'm lookin to get a nice set of tires but now if i go anything smaller profile size tire than stock...the speedometer reading will goes off.
my stock tire: 205/55/16
New Tire: 205/50/16
from Tire calculator: speedometre reading will be 3.2% too fast. speedo reads 60mph, but actually traveling 58.1mph
my question is, will that add up more mileage from traveling? whats bad side will affect my car?
any opinion pls.
Old Mar 16, 2007 | 05:29 AM
HONDA RR's Avatar
Default Re: Tire Size Question, pls help (spoonem2)
You should be ok. I'am running 195/50/15 when my stock size is 195/55/15.
Old Mar 16, 2007 | 08:53 AM
p nut's Avatar
Yes, you will be adding up more mileage than the actual mileage accrued. It won't be too much, though. Other than the speedo and odo being off by a bit, there will be no other negative side affects to your car.
Your smaller tires essentially change the gearing of the car (indirectly), which should improve acceleration times. Not by much, though.
Old Mar 16, 2007 | 09:15 AM
t-town_ep's Avatar
mine is
stock: 205/55/16
now: 205/40/16
i cant even tell that the speedometer is off, having a lower profile tire makes the car quicker, the only thing is that its so low to the ground.
tacothenasty
Mar 26, 2013 08:23 PM
mrchevez
Jan 12, 2011 10:19 PM
tampabitches
Aug 24, 2006 01:26 PM
alwaysoverkill
Feb 13, 2006 08:48 PM
krayjeegsr
Jan 4, 2006 03:51 PM
