99-00 si shift linkage same as del sol vtec Dohc linkage?
interesting, so you can't use the 99si linkage, even if you used the mounts from a 99si as well?
and is there different del sol linkage lengths? or will any 5spd linkage work?
Modified by crxcess at 8:25 AM 3/1/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxcess »</TD></TR><TR><TD CLASS="quote">interesting, so you can't use the 99si linkage, even if you used the mounts from a 99si as well?
Modified by crxcess at 8:25 AM 3/1/2007</TD></TR></TABLE>
For a B-series, you can only use a Del Sol VTEC shift linkage.
redline870
Mar 23, 2011 09:30 AM
SOLvtec
Oct 27, 2006 09:30 AM
