new accord owner with a few?s about swaping parts from a 98 to my 94
theres a junkyard that has a 97 i want to use the front leather seats off of it( my 94 is an ex but the seats are torn) i also need the gauge cluster they kinda looked the same at a fast glance? anyone know if i could use eaither part?
Modified by lshatch1.8 at 11:19 PM 2/28/2007
will the cluster work thow? the one i have now is messed up and has white face gauges
also is there any place to online to order the stock oem stock lip? what should i do about the tail lights it has some ebay wanna be si ones..
ok i made a big mistake after searching for a bit the parts are off a 97 w tail lights in the trunk will the seats bolt up and cluster direct fit? if so ill pick them up tommrow
Whoa my bad. My reading sucks.
Everything should work out fine. You wont need custom rails. If its power and such though you might need to do some stuff.
As for the cluster, just make sure if you have auto get a auto cluster. vice versa with a manual.
