car won't start after swap
Old Feb 28, 2007 | 07:55 PM
715_guy's Avatar
Default car won't start after swap
I have a 91 accord, after the timing belt snap, I decided to replace the engine since the car have 256,000 mi on it. I dropped a 92 accord f22a6 engine in, and now the problem is that it won't start...the starter did crank....but won't start...anyone please help...
Old Feb 28, 2007 | 07:58 PM
foist1's Avatar
Default Re: car won't start after swap (715_guy)
check; spark, injector pulse, compression, timing. Is that the same engine you took out? Do they look the same? (intake) If looking at front of car. Left side of exhaust manifold. Down a little on flat part of block. Look for F22A1, F22A4, or F22A6. on both blocks. If same look for a plug you missed. or Ill be back in 24 hours. Because im NEW TO THIS SITE.
Modified by foist1 at 9:16 PM 2/28/2007
Modified by foist1 at 9:32 PM 2/28/2007
Old Feb 28, 2007 | 08:08 PM
715_guy's Avatar
Default Re: car won't start after swap (foist1)
i replace the 91 to the 92 engine, but i'm not sure if they the same
Old Feb 28, 2007 | 10:47 PM
momstaxi's Avatar
reconnect your transaxle to body ground, most common i would say
or your engine harness ground to intake manifold or thermostat housing (not sure where 4gen harness ground is located)
Old Mar 1, 2007 | 04:27 AM
715_guy's Avatar
Default Re: car won't start after swap (momstaxi)
I will recheck everything, and I will let you guys know. Ok...i got the car started...b/c of not enough ground, but it idling btw 1000 to 1500 rpm when starting up the car. also, while the engine is running i can shift into 1 and 2 gears without press on the clutch. what could be wrong? and is the fan supports to run when connected to the battery? please help
Modified by 715_guy at 7:56 AM 3/1/2007
Modified by 715_guy at 7:57 AM 3/1/2007
bwk
Dec 29, 2017 04:49 PM
mattbandelt
Dec 17, 2012 08:49 AM
96accordky
Dec 15, 2009 04:38 PM
killacam661
25
Nov 17, 2007 12:19 PM
roorensu
Oct 17, 2007 10:38 PM
