clutch housing countershaft needle bearing part numbers
Baranco shows the part # as 91101-P80-008, retails for 63.78. 33x60x20 are the dimensions listed.
Majestic (Honda) shows the part (no part number) for the 2000 SI, retails for 24.65. 33x60x20 are the dimensions.
So we have a B16/ITR trans which are nearly identical except the LSD, with the same dimension bearings, and one bearing is almost 3x as much as the other. Any reason to think this bearing for the ITR tranny is any different? Or is it just because its an "Acura" part? Putting the Acura part number into the Majestic site states the part is not found.
