Using 3mm headgasket, affects t-belt?
Old Feb 28, 2007 | 06:11 PM
TegR's Avatar
Default Using 3mm headgasket, affects t-belt?
I'm using a inline pro 3mm headgasket for a week now. Since the head is lifted off the block 3mm's does this stress or stretch the timing belt? Because it's a lot harder to put the belt on now, this is on a b18c1.
Old Feb 28, 2007 | 06:57 PM
Stoich EG2's Avatar
Default Re: Using 3mm headgasket, affects t-belt? (TegR)
putting your timing belt on should be harder with 3 more mm to overcome. there shouldn't be a problem thought since you are using a tensioner.
Old Feb 28, 2007 | 08:16 PM
inspyral's Avatar
How's the tension on the timing belt with that thick of a headgasket? Did you adjust the cam gears to compensate for it?
Old Mar 1, 2007 | 07:54 AM
TegR's Avatar
Tension on the belt is the same, just harder to put on. I haven't timed it yet.
dleccord
Apr 13, 2020 08:03 AM
airikkCRX
Apr 2, 2010 08:29 AM
RoB316
Jul 22, 2007 03:40 PM
eddiecut
Jun 16, 2003 12:10 PM
