Dodge Neon Radiator
Old Feb 28, 2007 | 05:39 PM
RMXmitch's Avatar
Default Dodge Neon Radiator
I have heard several people say that we can use the Dodge Neon half radiator in our ef's, and they bolt right up.. I cannot find any info on google or on here.. Has anyone seen this done, and does anyone have any pictures of what they look like.
What year neons should I look for?
Will I have to custom make radiator hoses? (For B18B into EF)
I am just wondering if this is the easiest way to get a half radiator in my ef, to make as much room as possible when I go to turbo, thanks.
Old Feb 28, 2007 | 06:26 PM
njn63's Avatar
Default Re: Dodge Neon Radiator (RMXmitch)
You want a 95-99 non-a/c neon radiator. You need a inline filler neck as the radiator doesn't have one.
Here are some pics of EJ1 Wilcox's setup:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">The lower is stock. It was a total bitch to get on there. The neon radiator has a larger diameter than the stock Honda hose.
We had to wipe the hose end down with rubbing alcohol to relax the rubber so we could get it on there.
The upper hose is from an integra. I cut two 45 degree angles out of it, instead of putting the filler neck straight out from the radiator. I think doing two 45s worked out better.
https://honda-tech.com/zero...20160
Old Feb 28, 2007 | 10:21 PM
DiMpL3s's Avatar
NICE
Old Mar 1, 2007 | 12:52 AM
Redline130's Avatar
I have a Neon half size radiator in my race car. It fits great, saves a lot of space, and it functions quite well. Like it was mentioned above, you will need to use a filler neck with a pressure cap and do some custom fitting for the upper coolant hose.
Old Mar 1, 2007 | 02:00 AM
ME-B-N-ME's Avatar
so they fit hmm.. guess I will be taking a trip to the junkyard soon
Old Apr 13, 2007 | 01:21 PM
stemiched's Avatar
Default Re: (ME-B-N-ME)
any info on if the stock crx rad. fan will bolt up to it or will it need modified?
also where can you buy an inline filler neck?
also heard that the neon radiators suck, compared to the eg radiator is this true or just a bias opinion?
Modified by stemiched at 7:40 PM 4/13/2007
Modified by stemiched at 7:44 PM 4/13/2007
Old Apr 13, 2007 | 02:10 PM
firebane's Avatar
Del Sol Rad:
had to modify the lower rad support and the rad has to sit in a exact spot or the hood won't close.
Also using a 10" slim fan mounted on the front.
Old Apr 17, 2007 | 06:19 PM
stemiched's Avatar
Default Re: (firebane)
does anyone know our hose diamater? i need to know to get a filler neck...
also will the stock ef hoses work with some cutting?
Old Apr 17, 2007 | 06:21 PM
AzCRX's Avatar
Default Re: (stemiched)
you could also use the civic half radiator. That way you wont have to get a filler neck. I'm sure it would be just as easy to source one from a junkyard as a neon.
Old Apr 17, 2007 | 06:29 PM
stemiched's Avatar
Default Re: (AzCRX)
im getting a new radiator anyway, not a junk yard one, also did you read any of this thread? the neon radiator sits a lot nicer than the eg radiator, also you dont have to modify the lower suport at all, i know about the eg half rad, but i like the way the neon one sits better.
Old Apr 17, 2007 | 06:50 PM
91ed9's Avatar
firebane
pm'd about the EG radiator
Old Apr 17, 2007 | 07:30 PM
nihad's Avatar
I personal wouldnt use the neon one it kinda looks gay just get the eg. or find some other one.
Old Nov 18, 2013 | 08:34 PM
Red-Rocket's Avatar
Back from the dead with good info, I found the part number for this exact radiator if you really want to use it.
Dodge part #4495947
Rock auto has it under #CU1623 http://www.rockauto.com/catalog/more...075&cc=1431715
It has 1-1/4" inlets, same size as B-Series hoses
Core Height 15"
Core Width 11"
Core Depth 5/8"
QwkD16
Dec 10, 2008 03:07 PM
sasinorm01
Feb 21, 2007 07:16 PM
D-Man
Jan 19, 2002 07:26 PM
