crx cutting off
so i'm driving today n a little stuck in traffic.. i'm in second going slow n my car starts cutting off so i tap the gas a little to keep it on n it does n i manage to pull over n park. When i'm pulled over i tap the gas n the car goes back to normal. so i get home n change the rubber tube seals on my valve cover cus they were leaking oil into the spark plugs n wires. I clean the plugs out, clean all the oil....n i start driving againg n a lil while later the car starts cutting off againg so i pulled over n then it went back to normal. My friend saw my dizzy and said the timing is all the way retarded so dat could be the problem....so we adjust it. n i start driving n within the 20 minutes i drove it after dat it hasnt done it againg...do u guys think if ur dizzy has the timing all da way retarded da car would do dat? my rex is an obd1 mpfi dx....
h-duced
Mar 12, 2009 01:45 PM
