Timing belt tensioner question
Old Feb 28, 2007 | 12:35 PM
Jstitch's Avatar
Default Timing belt tensioner question
On the H22A guide for the swap i was wondering if anyone knew any more detail on "You may blow your engine only a few miles down the road , without fixing a little known problem with the timing belt tensioner on the H22." What does he mean can someone help me out with this??
Old Feb 28, 2007 | 12:55 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Timing belt tensioner question (Jstitch)
they are referring to the common problem with the H22 auto tensioners. You can convert to the H23 manual tensioners, look more in the FAQ and you'll see the link that shows the parts needed and how to convert it.
Old Feb 28, 2007 | 01:10 PM
Jstitch's Avatar
Default Re: Timing belt tensioner question (TouringAccord)
what if my car is an auto tranny??
Old Feb 28, 2007 | 01:32 PM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jstitch &raquo;</TD></TR><TR><TD CLASS="quote">what if my car is an auto tranny??</TD></TR></TABLE>
The transmission type will not make any difference on the T-belt tensioner issue.
Old Feb 28, 2007 | 01:42 PM
H-T Order of Merit
just look at the links and you'll quickly see why the tranny type doesn't matter.
Old Feb 28, 2007 | 03:40 PM
Jstitch's Avatar
So since i am doing the F22 to H22A swap is it really a requirement that i change the timing belt or will it work just fine with the one on the motor right now OEM
Old Feb 28, 2007 | 03:46 PM
H-T Order of Merit
you should be fine, but do you know when it was last changed? Do you want to chance maybe snapping a belt and screwing more things up? Also, it's a lot easier to replace the timing belt, timing balancer belt and water pump while the engine is out of the car.
serjey15
Nov 27, 2010 03:50 PM
Stuartz
May 1, 2007 07:48 AM
jk11blueboi
Feb 2, 2007 06:51 PM
MyVtec8yourV8
Nov 28, 2004 02:33 PM
