Setup decision made and car in the shop
Lately i've been jumpin around on ideas for my build up i have a 96 GSR that i had the head milled down to 10.5:1 compression and had port and polished. so my build will include:
-Bottom End-
JDM GSR (Si-R) Block
JDM ITR Pistons
Rebalanced JDM ITR Crank
JDM ITR connecting rods
Excedy Stage 2 Clutch
-Top End-
Previous Head which is a USDM GSR milled to 10.5:1
New Gaskets
Skunk 2 Stage 2 Valves, Springs, Retainers
Stock GSR Camshafts and Gears
Port and Polish
DC Sports JDM 4 to 1 Header w/ test pipe and exisiting RsR ex mag exhaust
Skunk 2 Intake manifold with cooling gasket
Post comments they can be mean i can take it
-Bottom End-
JDM ITR Pistons
-Top End-
New Gaskets
Port and Polish
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WarpedSportzKid »</TD></TR><TR><TD CLASS="quote">Lately i've been jumpin around on ideas for my build up i have a 96 GSR that i had the head milled down to 10.5:1 compression and had port and polished. so my build will include:
-Bottom End-
JDM ITR Pistons
-Top End-
New Gaskets
Port and Polish
sounds ok. looking like the allmotor route. expensive.
-Bottom End-
JDM ITR Pistons
-Top End-
New Gaskets
Port and Polish
Why spend all that money and stay with the stock cams? As long as you have it open may as well get forged pistons and rods and go for more power. If you are going to spend the money spend it so you will get some results! Look into upgrading you exhaust system as well.
Yes to upgrading your exhaust system. I just got a jdm type header for my jdm b18cR and its a night and day difference between my old DC Sports header.
Also while your rebuilding your motor why not throw some cams in theire? You be more happy with if if you do.
Vtec-Mike
Aug 23, 2007 03:16 PM
JdmEg6Hybrid
10
Sep 7, 2004 09:36 PM
NSTY Z33
May 11, 2004 03:56 PM
00 FBP ItR
Sep 18, 2003 12:22 PM
