B16a pr3 ecu flashing 4 times????
Old Feb 28, 2007 | 11:40 AM
90civicSiRacer's Avatar
Default B16a pr3 ecu flashing 4 times????
i had jus checked my ecu and it flashed 4 times at me wats this mean???? thnx for ur helps
Old Feb 28, 2007 | 11:57 AM
yz125rider21's Avatar
Code 4 - Crank Angle Sensor
Top sensor in the dist. and is used for fuel control and misfire detection.
If the dist. base bearing starts failing, it will start heating the sensor(s) up, destroying the magnetism causing a code(s). It will lose 10% of it's strenght, each time it is heated up, to a 170 degrees plus.
In most cases, replacing the distributor is the only alternative. Especially if the bearing has failed.
Honda does don't stock the bearing itself, but other after-market compaines are said to have one.
If you have problems starting the engine, or drivability after the install check your cam aligment. The seizing bearing might have caused it to jump a tooth/notch or two. From the extra drag due to the bearing failing.
Old Feb 28, 2007 | 12:06 PM
thanks ill check that out
Old Feb 28, 2007 | 12:09 PM
did it just start doing that or you dont know when it started???
Old Feb 28, 2007 | 12:13 PM
it started after the motor was put in i jus didnt know how to check for the engine codes i heard of 3 diff ways only 1 worked
Old Feb 28, 2007 | 12:25 PM
haha...ok
bertsb18hatch
Sep 15, 2007 04:01 PM
jdm206
Apr 28, 2007 12:18 PM
JinksItR
Feb 13, 2006 02:24 PM
crxturboh22
Apr 19, 2004 10:44 PM
6psihybrid
Oct 18, 2003 02:55 PM
