1994 Rear Hatch Popper, On a 1999 Integra GSR
Old Feb 28, 2007 | 10:54 AM
dc4g's Avatar
Default 1994 Rear Hatch Popper, On a 1999 Integra GSR
I have a 99 GSR and of course the Solenoid is giving me hell, I read that the 1994 integra have a Hatch release setup where the fuel door release is at.
Is it possible to install this along with a cable or is there more to it?
has anyone done this or thought of doing it>
Thanks
Old Feb 28, 2007 | 11:03 AM
DC4love's Avatar
ive had both a 94 and a 98 and my latch is giving me hell to but i dont know if you could transfer it over....prob have to change latches and fuel door release......most likely not worth it...
Old Feb 28, 2007 | 11:56 AM
98GSRDC2's Avatar
Default Re: 1994 Rear Hatch Popper, On a 1999 Integra GSR (dc4g)
dont know if you can. but the hatch is sure heavy.
Old Mar 1, 2007 | 12:07 PM
dc4g's Avatar
Default Re: 1994 Rear Hatch Popper, On a 1999 Integra GSR (98GSRDC2)
Is the rear hatch itself different or is it just a cable setup
Old Mar 11, 2007 | 09:56 AM
dc4g's Avatar
no one knows?
Old Mar 11, 2007 | 12:00 PM
Leo C's Avatar
Night Owl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc4g &raquo;</TD></TR><TR><TD CLASS="quote">Is the rear hatch itself different or is it just a cable setup</TD></TR></TABLE>
The 98+ hatch rsises higher I believe. Not sure if the part numbers are different from Honda. Bump f
Old Mar 12, 2007 | 09:42 AM
dc4g's Avatar
Default Re: 1994 Rear Hatch Popper, On a 1999 Integra GSR (Leo.C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo.C &raquo;</TD></TR><TR><TD CLASS="quote">
The 98+ hatch rsises higher I believe. Not sure if the part numbers are different from Honda. Bump f</TD></TR></TABLE>
not looking to replace the whole hatch, just the latch release assembly
Old Mar 12, 2007 | 10:16 AM
ac_attak's Avatar
Just use the key to get into the trunk. Its just as quick to use a key as it is to use the latch anyway.
Old Mar 12, 2007 | 04:33 PM
dc4g's Avatar
Default Re: 1994 Rear Hatch Popper, On a 1999 Integra GSR (ac_attak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak &raquo;</TD></TR><TR><TD CLASS="quote">Just use the key to get into the trunk. Its just as quick to use a key as it is to use the latch anyway.</TD></TR></TABLE>
Keep your ignorance out of my thread.
Old Mar 12, 2007 | 04:37 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc4g &raquo;</TD></TR><TR><TD CLASS="quote">Keep your ignorance out of my thread.</TD></TR></TABLE>
He has a legitimate point. If the electronic mechanism is giving you trouble, you can use the key to open the hatch.
To answer your question though, I'm sure you could do the conversion, though it would most likely be more trouble than repairing the solenoid.
Old Mar 12, 2007 | 05:53 PM
ac_attak's Avatar
How was that ignorance? Nobody is going to be able to tell you exactly what to do because nobody would go through all that pointless work when all you need to do is replace the solenoid or use your key.
Old Mar 12, 2007 | 06:35 PM
BLacK FirE's Avatar
How was that ignorance? Nobody is going to be able to tell you exactly what to do because nobody would go through all that pointless work when all you need to do is replace the solenoid or use your key.</TD></TR></TABLE>
Especially when the solenoid takes like 20minutes to install.
Old Mar 16, 2007 | 10:21 AM
dc4g's Avatar
Default Re: 1994 Rear Hatch Popper, On a 1999 Integra GSR (BLacK FirE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLacK FirE &raquo;</TD></TR><TR><TD CLASS="quote">
Especially when the solenoid takes like 20minutes to install.</TD></TR></TABLE>
I understand this, my point is If Im driving in my car and I want to POP my Hatch so my friends can put stuff in the back, I dont want to have to get my Key out and open it, or even with the solenoid replaced, I dont want people to have to fumble with the latch when I could just pull a lever, and POP it.
I guess you could say i have trunk envy.
Thanks for you input I will continue my endeavour
journeyquest
Sep 3, 2010 02:47 PM
JDM manc 10
Sep 18, 2006 11:50 AM
cm zak
Feb 11, 2006 06:15 PM
JdMCiviCCupE
Dec 7, 2003 12:16 PM
nugen power
Oct 14, 2003 12:26 PM
