bypassing the "U" hose from the intake to water pipe question......
Old Feb 28, 2007 | 06:32 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default bypassing the "U" hose from the intake to water pipe question......
you all know the "U" shaped hose from the intake manifold to the coolant pipe, tstat housing, can i plug it? i am trying to run as little coolant hoses as possible. i know it is pretty much a bypass, but is it necessary? the car will see very little of the street as there are too many people waiting for me to leave it outside my garage.
thanks in advance.
Old Feb 28, 2007 | 09:09 AM
redboost10's Avatar
Default Re: bypassing the "U" hose from the intake to water pipe question...... (boostedcivicsir)
i had coolant temp issues when i capped them off.
not sure if your using this or not, but if you wanna at least shorten the hose to at least a third of the length of the orignal U hose, get a 96-01 gsr therm casing, and it has a 90* hose fitting in it already, unlike the b16 where it has a straight fitting.
Old Feb 28, 2007 | 09:11 AM
Mr. Badwrench
Default Re: bypassing the "U" hose from the intake to water pipe question...... (redboost10)
10-4 thanks looking for more. thought about going braided with it too.
Old Feb 28, 2007 | 09:13 AM
redboost10's Avatar
yeah no problem, heres a thread when i was looking for mine, i think these guys still have them, its a pretty recent thread
http://www.hondamarketplace.co...95550
Old Feb 28, 2007 | 09:18 AM
DaveF's Avatar
definitly do not bypass that loop hose, it helps get the thermostat hot, and allows the water to circulate around. if you block it off the car will either overheat or run hot. (i did this on my black coupe, thats how i know what happens when the hose is not looped)
Old Feb 28, 2007 | 09:31 AM
Mr. Badwrench
Default Re: bypassing the "U" hose from the intake to water pipe question...... (dturbocivic)
10-4 thanks everyone......dave you got pm.
Old Feb 28, 2007 | 09:32 AM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboost10 &raquo;</TD></TR><TR><TD CLASS="quote">yeah no problem, heres a thread when i was looking for mine, i think these guys still have them, its a pretty recent thread
http://www.hondamarketplace.co...95550</TD></TR></TABLE>
looking through my recycled parts, i just found one thanks.
Old Feb 28, 2007 | 05:04 PM
Quik Chris's Avatar
It's called the coolant bypass hose coinsidentally...
qhiggy
Sep 8, 2015 09:12 PM
efjones9
Oct 11, 2010 04:17 PM
Prod
Sep 16, 2004 07:29 AM
KF_S2000
Aug 6, 2002 07:36 PM
KF_S2000
Aug 6, 2002 04:46 PM
