NoVa 92-95 civic parts and 89-91 crx parts, b18a swap for sale, trade
I have pictures of everything. I will start posting soon, or I can email them to you. I'm located in Ashburn, right near Dulles Airport.
Integra LS B18a swap 5spd trans OBD0 $700 or best offer takes it
I’ve got a rebuilt B18a for sale – OBD0
Comes with
5spd manual transmission
intake manifold w/ fuel rail, injectors
engine harness
$700 obo(willing to separate motor and trans, but motor must sell first)
Came out of a 91 integra LS. The car had 105k on it. The bearings, rings, seals, and gaskets were replaced, and the motor went into a crx. The car lasted 5k miles. The previous owner lost traction on a turn, slid off the road, dropped a wheel into a ditch, and managed to turn the car over.
The car had been started afterwards, but with the roof damaged, it was deemed a total loss. The transmission works normally, but I have been told it has a slight grind going into 5th gear. That’s a very easy repair, especially with the motor already out of the car.
The car also has a no-name brand 4-2-1 header. The collector has been cut off the end. This is good, especially if you plan on putting this motor into a 88-91 civic or crx. Rather than cut your exhaust or cat, just get an extension put on the header.
CRX PARTS – all interior parts are from a crx si or dx with black interior. I have pics available for every thing on this list, let me know what you need. This is all the remaining crx parts I have. I would be willing to trade for some parts at the bottom of the list.
CRX b-series swap mounts and linkage - $80
I got the mounting brackets to put this swap into a 88-91 civic or crx. I do not know the name brand, but I suspect they are just ebay mounts.
The shift linkage is from the 91 integra, and has been cut and welded to the correct length. Still, for $80, you can’t beat it.
crx foot rest and cover plate - $5
door window cranks - $5
e-brake light – this is the light housing that goes on the crx hatch - $1
coin tray - $1
spare tire clamp – the bolt and washer that holds down the spare tire, still shiny - $1
right side door panel – for a 88 crx, or 89 hf, only the top grey part is good. There is a nick in the vinyl near the door cup. The top part, and the felt that says crx are in great condition - $20
right side door panel cup - $5
rear view mirror – with cover plate - $5
gas lid – no dents - $5
rear interior light – the little light that goes on the trunk panel - $5
ceiling light - $5
speedometer cable – from a 89 crx si - $5
sunroof switch – with plug and a length of wiring - $5
e-brake boot- no rips or tears - $5
blower motor – heater blower motor with solenoid - $5
trunk carpet – the carpet is attached to the upright part of the storage box. The board itself is no good, but the fabric is in excellent condition and can be reused. - $15
B-series swap AC bracket – this bracket allows you to mount your ac into a civic or crx with a b-series swap - $100
rocker trim piece – this is the trim part that goes on the front fender behing the wheel, at the bottom of the fender. It connectos to the long rocker panel cover. This is for the right side - $10
CIVIC PARTS – All of these parts are from a 95 civic ex coupe, will fit any 92-95 civics.
outer tail tights – there is a hairline crack in one of the tail lights. Barely noticeable, but it is there, I have pics if you are interested - $25
grey cloth back seats –there is a spot on thop where there is a fold in the fabric. Something was laying on it for a while. I think it’ll straighten itself out over time. Also there is one tiny cigarette burn. It didn’t go through, but it is there. I have pics of this too. - $30
grey cloth front seats – the frames are bent on these seats, but the fabric and the foam are in very good condition. Could be used to cover your existing seats, or bent these back to the straight position. The passenger seat is barely crooked. No rips, tears, or burns. Comes with seat rails - $40
Front fender mud flaps - $20
e-brake lever with handle and boot – looks new - $10
blower motor - $10
WANTED:
These are the parts I’m currently looking for, I’d be willing to trade with any of the parts listed above.
92-95 civic ex/si instrument cluster for a manual trans
92-95 civic hatchback black rear speaker covers
94-01 integra manual hydraulic transmission – any condition except a cracked case
92-95 civic 2dr passenger side fender. needs to have original black paint. some dents ok. no damage to edges though.
92-95 civic 2dr power window switches- in black
P30 ecu
92-95 civic 2dr stock headlights - no cracks or broken housings please
Comes with
engine harness
coin tray - $1
ceiling light - $5
blower motor - $10
WANTED:
P30 ecu
crxb16d2
Oct 11, 2008 08:23 PM
vtec-adykt
Jun 29, 2005 11:59 AM
