Really noob ?. Please dont flame
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_2k5 »</TD></TR><TR><TD CLASS="quote">or instead of ******* **** up put on some rims that are made to fit, not like the hx look worth a **** anyway</TD></TR></TABLE>
Or, post something worth while that someone could possibly benefit from. He ask if it was possible, and if so; how. Not "will theze rimz look tight yo!?"
OP: Spacers would work best. They can be found on ebay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_2k5 »</TD></TR><TR><TD CLASS="quote">or instead of ******* **** up put on some rims that are made to fit, not like the hx look worth a **** anyway</TD></TR></TABLE> You're a tool, GTFO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm »</TD></TR><TR><TD CLASS="quote">Shave down the caliper face, get spacers, or shave down on the inner part of the rim.
</TD></TR></TABLE> Those suggestions are all possible, but the easiest would be the spacers.
I had a buddy with HX wheels on his DA and he used 3 or 5mm(dont remember) spacers and it worked perfect. Just make sure to find hub centric spacers or your wheel shimmy at freeway speed as if the wheels were not balanced.
fine if you guys want to go through the work to put on shitty *** civic rims more power to ya. doin **** like that is the epitomy of doing **** halfassed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_2k5 »</TD></TR><TR><TD CLASS="quote">fine if you guys want to go through the work to put on shitty *** civic rims more power to ya. doin **** like that is the epitomy of doing **** halfassed</TD></TR></TABLE>
Your a dumb *** and so is P Nut. The whole point is not for looks. Have you ever see HX on a DA, it looks ok, and it isnt the best looking wheel I agree, but HX wheels are stupid lite. Its ok to put spacer on a car. Sports cars like the M3 and the 911 are built to run spacer from the factory for certain suspension setups and wider rims. Also the guy didnt ask you for your opinion what you think about it, he just wanted to know how to do it. hence the tech section.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg »</TD></TR><TR><TD CLASS="quote">
Your a dumb *** and so is P Nut. The whole point is not for looks. Have you ever see HX on a DA, it looks ok, and it isnt the best looking wheel I agree, but HX wheels are stupid lite. Its ok to put spacer on a car. Sports cars like the M3 and the 911 are built to run spacer from the factory for certain suspension setups and wider rims. Also the guy didnt ask you for your opinion what you think about it, he just wanted to know how to do it. hence the tech section.</TD></TR></TABLE>
Care to post a link to this assumption of yours? You think the R&D crew at BMW and Porsche team up with some wheel spacer manufactorer so they can run their suspension specs according to a wheel spacer?
Here is another aspect that you probably overlooked--how many performance tires are available for 14" rims? I could only find a couple decent tires for a 14" rim. On the other hand, there are TONS of 15" performance tires available--RT615's, S03's, RE010's, etc. etc. Not to mention R-Comps. So if the whole point is not for looks, and obviously it's not for performance--what is the point?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut »</TD></TR><TR><TD CLASS="quote">So if the whole point is not for looks, and obviously it's not for performance--what is the point?</TD></TR></TABLE>
Cheap cheap daily beater wheels and tires, without rolling steelies.
