Ride height ...cant seem to figure it out
Alright. So this is the situation. My driver side coilover is set about an inch higher than the passenger side, but when the car is on the ground, it sits pretty even. Which means the passenger side has an inch less of shock travel...right?...Theoretically. When i count the threads and make them both evenly spaced on both sides, the passenger side sits higher then the driver side. I don't know what it is that is throwing this off. I'm think bushings, but bushing cant do this...or will it? This just sucks because i would the fronts to be set up the same as the backs are the same. btw, I'm using skunk2 ps.
lunareg
Suspension & Brakes
23
Apr 13, 2011 07:04 PM
