TW/FS: D16Z6 built block / SOHC turbo parts (Wiseco, Eagle, Greddy, Tial, Turbosmart, RC, etc.)
Old Feb 27, 2007 | 06:42 PM
DelSolDon's Avatar
Default FS: SOHC Exedy Stage 2 Cerametallic Clutch Kit
I'm parting out my built D16Z6 and turbo setup that I had on my '90 SI. Parts with mileage used and prices are below:
.:Turbo Misc. stuff:.
I have more detailed pics if needed of the clutch and pressure plate
Exedy Stage 2 Cerametallic Clutch Kit <FONT COLOR="#006600">(clutch disc, pressure plate, brand NEW throwout bearing, alignment tool, NO pilot bearing; all with about 100 miles use)</FONT>
<FONT SIZE="2"><FONT COLOR="#FF0000">SOLD</FONT></FONT>
.:SOLD Items:.
.:D16Z6 short block:.
<FONT COLOR="#000099">all parts have less than 100 miles on them, never boosted higher than 7psi.</FONT>
<FONT COLOR="#006600">Wiseco 75.5mm K546M755 8.5:1 pistons and rings
Eagle CRS5394HO rods w/ 3/8" ARP 2000 Bolts
OEM Honda oil pump
OEM Honda water pump
OEM Honda bearings (rods, mains, thrust)
OEM Honda rear main seal
tapped oil pan w/ OEM pan gasket and magnetic drain plug</FONT>
<FONT COLOR="#FF0000">SOLD </FONT>
.:D16Z6 head:.
<FONT COLOR="#000099">OEM valve seals changed less than 100 miles ago</FONT>
<FONT COLOR="#006600">stock cam w/ Megan 6-bolt adj. cam gear
valve cover and VTEC solenoid included
no dizzy and no manifolds</FONT>
Garrett T3/TO4E 50 trim w/ .48 a/r Turbo
<FONT COLOR="#000099">SOHC short ram style manifold, downpipe (5-bolt, 2.5" to 3" flex pipe after oil pan), DEI heat-wrapped dumptube (all painted with VHT 1500* flat black paint and baked on)</FONT>
<FONT COLOR="#006600">3" downpipe back full stainless exhaust.</FONT> Welded in some spots, clamped in others, has downpipe that is listed above still clamped to it, but I can separate. The part that goes up and over the rear lower control arm is full stainless steel flexpipe, not the cheap crap.
Magnaflow muffler, painted flat black.
Tial 38mm wastgate
Greddy Profec Type-S EBC
<FONT COLOR="#006600">(used for less than 100 miles, but always kept at lowest setting, so as close to new as you can get)</FONT>
4-RC 550cc peak and hold (low impedance) injectors
no-name catch can w/ braided lines
stealthmode firewall kit (used for ~100 miles)
Modified by DelSolDon at 8:33 PM 6/11/2007
Modified by DelSolDon at 8:34 PM 6/11/2007
Old Feb 28, 2007 | 12:16 PM
DelSolDon's Avatar
Default Re: TW/FS: D16Z6 built block / SOHC turbo parts (DelSolDon)
bump
Old Feb 28, 2007 | 06:46 PM
DelSolDon's Avatar
up for pictures
Old Mar 1, 2007 | 01:18 PM
b18_ef_hatch's Avatar
Pm'd again
Old Mar 2, 2007 | 07:05 AM
DelSolDon's Avatar
Default Re: TW/FS: D16Z6 built block / SOHC turbo parts (b18_ef_hatch)
bump
Old Mar 2, 2007 | 05:09 PM
DelSolDon's Avatar
deposit received for longblock, sorry to those that were interested, will update if deal falls thru.
Old Mar 3, 2007 | 10:52 AM
DelSolDon's Avatar
turbo pending
profec type-s pending
Old Mar 3, 2007 | 07:55 PM
DelSolDon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon &raquo;</TD></TR><TR><TD CLASS="quote">turbo SOLD
profec type-s SOLD</TD></TR></TABLE>
Old Mar 4, 2007 | 04:56 PM
DelSolDon's Avatar
clutch added
Old Mar 5, 2007 | 08:40 AM
DelSolDon's Avatar
bump
Old Mar 6, 2007 | 12:04 PM
DelSolDon's Avatar
bump
Old Mar 8, 2007 | 08:48 AM
DelSolDon's Avatar
up again
Old Mar 10, 2007 | 07:47 AM
DelSolDon's Avatar
bump
Old Mar 12, 2007 | 07:17 AM
DelSolDon's Avatar
BUY
Old Mar 12, 2007 | 09:59 AM
Did that guy come pick up the motor? If not, I'm still interested.
Old Mar 12, 2007 | 11:40 AM
DelSolDon's Avatar
still waiting to hear from him. he was supposed to be back in town yesterday.
EDIT: just talked to him, everything is still a GO
Modified by DelSolDon at 3:58 PM 3/12/2007
Old Mar 12, 2007 | 11:48 AM
Let me know asap before I go buy this other motor I found I really want to work something out to buy yours if that guy flakes on you.
Old Mar 13, 2007 | 12:37 PM
DelSolDon's Avatar
bump for update
Old Mar 14, 2007 | 05:52 AM
DelSolDon's Avatar
up again
Old Mar 15, 2007 | 02:18 PM
DelSolDon's Avatar
bump
Old Mar 16, 2007 | 12:25 PM
DelSolDon's Avatar
buy the rest
Old Mar 19, 2007 | 01:35 PM
DelSolDon's Avatar
up again
Old Mar 21, 2007 | 07:12 AM
DelSolDon's Avatar
bump
Old Mar 22, 2007 | 06:57 PM
DelSolDon's Avatar
up again
Old Mar 24, 2007 | 07:08 AM
DelSolDon's Avatar
bump
