No camber kit needed? True or False?
I read this in the suspension forum many times. Some says that the inside of the tires does not wear because of the camber, it is because of the toe. To fix the inside tire wear problem, all you need to do is fix the toe at an alignment shop. Is this true or false for accords (97 accord)?
It takes a LOT of camber to create any decent amount of tire wear. Incorrect toe causes rapid tire wear.
With many cars, toe angles change as you turn the wheel. (As an example, as you turn the steering wheel more, the inside wheel experiences a greater amount of toe-out.) If the car is lowered, the toe angles can change even more. This creates irregular tire wear on the very inside edge, which most people mistakenly call camber wear.
I have a '99 Accord, lowered roughly 1.75 inches with only a rear camber kit. My front camber is well within factory alignment specs (without a camber kit) and front toe is at 0. I still experience accelerated tire wear on the very inside of the tread.
another problem i hear a lot is when you put on the front camber kits it is too high and will hit the upper inner fender or something. so is front camber kit needed to save the life of the tires? or just alignment to fix the toe?
Coopa B18c5
Jan 18, 2013 07:58 PM
