1.6 injectors on my 1.5 crx dx affecting gas mileage?
Old Feb 27, 2007 | 04:51 PM
hondacivic90zc's Avatar
Default 1.6 injectors on my 1.5 crx dx affecting gas mileage?
i recently did an si conversion on my 88 crx dx with the full harness, ecu, intake manifold, and fuel injectors. I was wondering how much 1.6 injectors would hurt my gas mileage since they are only feeding a 1.5. It has the stock D15B2 with 230000 miles and it is a 5 speed. The only code it will throw is for the O2 and for the throttle position sensor. The blinks on the ecu go 1 1 7 and on and on. It only happens when i am going steady paced for awhile. When i shut off the car and restart it the code is gone until it pops up again. Does anybody have an idea what would cause this?
Any help would be appreciated.
Old Feb 27, 2007 | 05:10 PM
sirtef9's Avatar
Default Re: 1.6 injectors on my 1.5 crx dx affecting gas mileage? (iandavis90)
how is it wired? pics plz
Old Feb 27, 2007 | 05:56 PM
gibsanez's Avatar
I'm pretty sure even the multiport D15 injectors flow the same as the D16 injectors. I'm assuming you wired the injector resistor in.
Old Feb 27, 2007 | 06:01 PM
Default Re: 1.6 injectors on my 1.5 crx dx affecting gas mileage? (gibsanez)
yeah the resistor is wired in
it is wired with the stock si harness and every sensor, etc that went with it
Default Re: 1.6 injectors on my 1.5 crx dx affecting gas mileage? (sirtef9)
i cant upload pics to my computer, but it is done like stock
Old Feb 27, 2007 | 06:08 PM
jpciii's Avatar
most people who do a simple dpfi to mpfi swap onto a d15b2 engine report improved gas mileage... not worse.
Old Feb 27, 2007 | 07:43 PM
Tippyman's Avatar
mpfi gets better mileage than a dpfi. Something is wrong.
Old Feb 27, 2007 | 07:48 PM
Default Re: (Tippyman)
i realize that but do you have any idea what it could be
Old Feb 28, 2007 | 07:08 PM
jpciii's Avatar
you say you used the full si harness??? I thought that an si harness doesn't connect up to a dx car. The only way is to cut the needed connectors off the si harness and splice them into the dx harness.
Old Mar 1, 2007 | 02:16 PM
Default Re: (jpciii)
no you have to use the full engine harness as well as the dash harness because the cluster connects differently so you also need a different gauge cluster. But other than that the harness works great.
Old Mar 1, 2007 | 02:25 PM
dr_latino999's Avatar
Default Re: (iandavis90)
Wow, that sounds like a hell lot of work to avoid adding 6 wires.
Old Mar 1, 2007 | 02:29 PM
HondaHeddie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iandavis90 &raquo;</TD></TR><TR><TD CLASS="quote">no you have to use the full engine harness as well as the dash harness because the cluster connects differently so you also need a different gauge cluster. But other than that the harness works great.</TD></TR></TABLE>
That is a new one on me.
Look at the FAQ
It will tell you where to check.
Just be prepared to get pissed.
It will show you how much extra work you did on your swap
and yes mpfi should improve your mileage.
chris266
Jun 8, 2008 09:51 PM
hondacivic90zc
Feb 22, 2007 06:56 PM
baked_beanz
May 25, 2005 01:56 PM
AGPSuperstar
May 15, 2003 06:55 PM
Josho_17
Mar 20, 2003 04:50 PM
