GSR KABOOM! not so good
Old Feb 27, 2007 | 04:23 PM
vtec8804's Avatar
* B A N N E D *
Default GSR KABOOM! not so good
so driving to pick up a car for work today going throu an intersection at about 35-40 mph 5th gear.... engine stalls and i drift into a parking lot, i go to restart it, but the idle seems unsteady and if u give it gas rpms drop to almost 0 and come back up, no cels. i restarted it n got it to my hosue literally a block down the steet lucky me i guess. but im guessin its the timing belt skipped or i broke some teeth.. there is also a horrible tinging sound coming from the engine bay when u give it slight gas.
dk if how true this is but i heard if ur timing belt goes it most likely takes the top end with it.. idk someone give me an idea at what im lookin at for both situations
.this has never happened to me b4 and i have never had any serious problems..but anyways i have a 98 gsr with 124xxxmiles.
so my ? doies anyone know what this is or agree with what i think? i dont have time to mess with it or get it looked at till the weekend thanks.
Old Feb 27, 2007 | 04:38 PM
RedEj8's Avatar
Default Re: GSR KABOOM! not so good (vtec8804)
Its blown..ship the motor to me
Old Feb 27, 2007 | 04:43 PM
vtec8804's Avatar
* B A N N E D *
Default Re: GSR KABOOM! not so good (RedEj8)
lol no really idk how im laughing bc it makes me pretty sad at the same time i came home n knocked my door off its hinges its laying in the hall..but any opinions suggestions ?
Old Feb 27, 2007 | 05:38 PM
nafreak's Avatar
/end yourself
Old Feb 27, 2007 | 05:39 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: GSR KABOOM! not so good (nafreak)
wheres vag pa
Old Feb 27, 2007 | 06:23 PM
RedEj8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec8804 &raquo;</TD></TR><TR><TD CLASS="quote">lol no really idk how im laughing bc it makes me pretty sad at the same time i came home n knocked my door off its hinges its laying in the hall..but any opinions suggestions ?
Well the only real way to tell what is wrong is for someone to know what theyre doing look at it..youd have to take the timing covers off and see if the TDC mark lines up with the cam gear marks.Check ur spark plugs, take a look under the dist cap and do a compression test for starters.
Old Mar 4, 2007 | 08:35 AM
vtec8804's Avatar
* B A N N E D *
timing is perfect..spark plugs are fine..were going to do a compresion test tomrow
Old Mar 4, 2007 | 09:05 AM
IntegrasAreBest's Avatar
let us know how the compression test comes out.
Old Mar 4, 2007 | 10:05 AM
Schister66's Avatar
Man U FTW
That has to suck....let us know about the compression test and good luck
Old Mar 4, 2007 | 11:44 AM
Dealer Leaf's Avatar
Default Re: (Schister66)
Dont drive it! That tinging sound is probally a piece of valve bouncing around scratching up your cyl walls. Leakdown test and you will be able to tell. Basicly you forcing air threw the s park plug holes on each cyl. comes out intake, valve on intake side, exhaust, etc etc. dont forget to rotate the engine so that each cyl's valves are closed. You can rotate the engine by using a socket and breaker bar on the crack pully bolt.
More at Team-Integra.net
if you get lucky all you will need is a Timing belt, head gasket, 1 valve (E or I Depending) and Fluids.
if you have one of those magnet on a stick tool you can reach down inside the spark plug hole and see if you get any valve fragments
Old Mar 4, 2007 | 04:17 PM
vtec8804's Avatar
* B A N N E D *
its been chillin in the garage..ill let u guys kno thanks
Old Mar 4, 2007 | 09:54 PM
FlyBMXer4130's Avatar
Just a side note, 35mph in 5th gear = not so good...
Old Mar 5, 2007 | 03:34 AM
vtec8804's Avatar
* B A N N E D *
it was slopped downhill.. i wasent trying to race someone in 5th from 35 i kno what u mean i was just crusing
Old Mar 5, 2007 | 04:21 AM
95 integra's Avatar
Default Re: (vtec8804)
Could be that your fuel pump went out (or is on its way) and its delivering just enough fuel to let the car idle and then dies off when more fuel is needed.....not real likely, but possible.
Old Mar 5, 2007 | 04:34 AM
Dogginator's Avatar
Daisy... Daisy...
Do you have the stock ECU? Does your CEL illuminate when you start the car like it is supposed to? I find it hard to believe that you have this list of problems without a single CEL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlyBMXer4130 &raquo;</TD></TR><TR><TD CLASS="quote">Just a side note, 35mph in 5th gear = not so good...</TD></TR></TABLE>
I pull hills at 25MPH in my 97 GSR. If I recall correctly, 35MPH is the recommended shift point to 5th gear as outlined in the owner's manual.
Old Mar 5, 2007 | 05:04 AM
vtec8804's Avatar
* B A N N E D *
stock ecu..driving the car under normal conditions in 5th gear..just coasting on a downhill sloped road
Old Mar 5, 2007 | 12:07 PM
Dogginator's Avatar
Daisy... Daisy...
Check your fuel filter.
Old Mar 5, 2007 | 12:25 PM
sneakysneaky's Avatar
I would just pull the head as chances are its a valve or worse.
Also is it a pinging, clanking, or knocking sound?
Old Mar 5, 2007 | 01:07 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (FlyBMXer4130)
reasoning?
Old Mar 6, 2007 | 04:30 AM
vtec8804's Avatar
* B A N N E D *
knocking sound...its not a heavy knocking sound like a rod..
Old Mar 7, 2007 | 06:15 AM
vtec8804's Avatar
* B A N N E D *
what should the compression test results come out to be..ive heard if they are all close im ok n what about letting the engine warm up? in my case it dosent sound good to let the engine run for more then 10secs so can a cold engine yeild accurate results?
Old Mar 7, 2007 | 03:15 PM
vtec8804's Avatar
* B A N N E D *
buummmmp
Old Mar 9, 2007 | 06:04 AM
what were the results of the compression test?
Old Mar 9, 2007 | 08:56 AM
Infamous_Imports's Avatar
This happened to me a couple months ago and for the longest I couldn't figure out what it was. After awhile I looked and saw it was the timing belt that had slipped and basically did take the top end w/it. I ended up going through 3heads before I decided to just scrap the motor and get a new one.
Come to find out the head that was originally on there had 3 bent valves and somehow warped...this was with 89,xxx miles on it.
Old Mar 9, 2007 | 03:07 PM
vtec8804's Avatar
* B A N N E D *
timing was perfect...idk how i have survived without my car for a week but guy was supposed to bring over a comrpession tester on mon then wed now tomorrow...im just gunna buy one myself. ftl
