ex header on lx and head
Old Feb 27, 2007 | 03:55 PM
sony224422's Avatar
Default ex header on lx and head
if i want to swap my f22 non vtec head with the ex vtec is it possible to do? and im assuming i'd need the ex ecu.
also, how hard is it to put the EX header on a LX, what doesn't bolt up and what has to be modified.
Old Feb 27, 2007 | 03:59 PM
hondadude's Avatar
Default Re: ex header on lx and head (sony224422)
the only comment I have is, the stock exhaust manifolds are different.
Old Feb 27, 2007 | 04:08 PM
philadd's Avatar
Default Re: ex header on lx and head (hondadude)
For your first question, there's a write-up in the Accord FAQ.
Your second question is asked quite often... All you will need to do is extend the O2 sensor wires, since the sensor is located further downstream on the EX manifold. I can't comment about the heatshield though.
Old Feb 27, 2007 | 04:22 PM
sony224422's Avatar
Default Re: ex header on lx and head (philadd)
yeah i wasn't sure about the heat shield. I mean i could just use a EX one couldn't i? or do they not have one. But i was told the EX doesn't bolt up exactly
Old Feb 27, 2007 | 04:27 PM
sony224422's Avatar
oh and the writeup is for a 4th gen. and an OBD1. i have an OBDII
Old Feb 28, 2007 | 11:04 PM
sony224422's Avatar
im just gunna get the EX header, and see if i can still use the LX heat shield with some customization
Old Mar 1, 2007 | 03:12 AM
TouringAccord's Avatar
H-T Order of Merit
the F22B1 manifold bolts up just fine to the F22B2. I sold my F22B1 exhaust manifold to a member on here who put it onto a F22B2 (don't remember the trim of their car though). All he said he had to do was extend the O2 sensor wires like stated above, nothing about not bolting up to the head.
The F22B1 manifold does have a heat shield, but I don't know if the F22B2 heat shield will fit. You could most likely go to a junkyard and pick one up for real cheap though.
Old Mar 1, 2007 | 07:03 AM
sony224422's Avatar
Default Re: ex header on lx and head (TouringAccord)
yep got someone on here to sell me one with a heat shield.
Old Mar 1, 2007 | 07:11 AM
H-T Order of Merit
IDK, best bet is to check the FS/WTB sticky.
If I still had the heat shield from my F22B1 (couldn't find when I sold the manifold, found later, then thrown out) I would send it to you for the cost of shipping.
Old Mar 1, 2007 | 01:30 PM
sony224422's Avatar
haha, no problem. i found someone on here willing to do the header and heat shield for $70 shipped so im happy
Old Mar 1, 2007 | 01:31 PM
sony224422's Avatar
but just to make sure, its the same gains as like a DC sports or any other aftermarket header for my LX correct?
Old Mar 1, 2007 | 01:47 PM
H-T Order of Merit
From what I've been told, yes, the designs are the same.
Old Mar 1, 2007 | 02:53 PM
sony224422's Avatar
thank you, all i needed to know
chris94accord
May 11, 2007 05:04 AM
Tech-Nics
Aug 5, 2006 04:33 AM
skweaky
Mar 26, 2006 09:07 PM
gringo7718
Jun 26, 2002 10:18 AM
gringo7718
Jun 21, 2002 01:14 PM
