Has anyone ever used Toyota Supra 440cc turbo injectors for their turbo set-up?? help
Old Feb 27, 2007 | 03:52 PM
Xemu's Avatar
Default Has anyone ever used Toyota Supra 440cc turbo injectors for their turbo set-up?? help
I bought these because one:I got a good deal,two:they were low mialege and in great condition and three:figured I could use them like the the Mitsubishi Eclipse DSM 450cc blue tops.But when I got them I had trouble with fitment into my Y8 manifold.Anyone have a remedy for this other than buying other injectors?? Has anyone used these with any success?? Thanks guys any info would help a great deal!!
Old Feb 27, 2007 | 04:21 PM
HiProfile's Avatar
Default Re: Has anyone ever used Toyota Supra 440cc turbo injectors for their turbo set-up?? help (Xemu)
Most aftermarket injectors are a bit too large for the stock honda injector seals, and end up being a bit short. Changing the brown spacer height on the fuel rail and dremeling the seals is usually what you have to do.
As far as the supra injectors themselves go, people have been using them on hondas probably since before you owned a honda.
Old Feb 28, 2007 | 01:59 PM
Xemu's Avatar
Default Re: Has anyone ever used Toyota Supra 440cc turbo injectors for their turbo set-up?? help (HiProfile
Yeah they fit good with the seals they just don't go far enough down into the intake for me.They just look like they should go down more.Fuel rail also isn't an issue they fit fine in the fuel rail.
donaldmejr
Apr 20, 2008 07:57 AM
spotscivic
Nov 23, 2007 08:20 PM
00ek9civicjay
Apr 29, 2005 09:37 AM
phoQ
Mar 29, 2005 10:31 AM
