window roll up!! easy question
Old Feb 27, 2007 | 03:44 PM
si90rex's Avatar
Default window roll up!! easy question
will a civic hb window roller upper. lol work in a crx? my window keeps coming out of the track when i roll it up unless i hold it in place!
thanks for any help
Old Feb 28, 2007 | 12:32 PM
si90rex's Avatar
Default Re: window roll up!! easy question (si90rex)
bump
Old Feb 28, 2007 | 01:19 PM
Burgess0909's Avatar
don't know about the civic roller, but you should check the tracks on ur window. take the door panel off, and make sure that the roller arm that is closest to the door lock is still in the track. This would cause the problem you have. You will need to reach your arm inside the door to feel if it is still in the track, as it will appear that it is when infact that section has come out.
Old Feb 28, 2007 | 03:47 PM
si90rex's Avatar
Default Re: window roll up!! easy question (Burgess90crxvtec)
i've took out the window 3 times before i posted this! my poller upper thing must be bent. i have one for a civic but don't know if it will work.
Old Feb 28, 2007 | 03:56 PM
Crx Jimmy's Avatar
just buy it new from honda, I bought a new one after fiddling with mine forever. Its like $40 its called the window regulator. Money well spent, no more holding the window when its going up or down
Old Feb 28, 2007 | 06:19 PM
si90rex's Avatar
Default Re: window roll up!! easy question (Crx Jimmy)
it 60 bucks. i checked it out before i did all this. i have a civic's for free. so i want to know if it will work before i spend the money.
8YourV8
Dec 13, 2010 10:09 AM
smooz EK
11
Dec 5, 2006 12:08 PM
hott-nix
Apr 3, 2005 04:04 PM
EnKidu
Oct 10, 2004 06:43 PM
fearless_dsm
May 24, 2003 11:15 AM
