dsm injectors++vfac II++ nos wet system++eg jdm cluster++b16 dist++jdm p30++arp
eg cluster (jdm) amber.
top line rod bearings for d15 (brand new)
arp head studs for d16y head (single cam) (used for 10 min)
nos nitrous wet system w/ purge kit
eg cluster non tach
ek cluster non tach
dsm injectors blue tops
rsx bose amp (stock)
b16 dist. obd I
set of b series cam gears
vafc II (black) w/ apex extension harness
obdII to obdI jumper harness
jdm p30
obd I engine harness (came out from my 94 ex coupe )
b16 starter
boost, oil press ,water temp gauges
b16 head ( ported and polished)
b series shift linkage
b18b long block
<U>pm me if anything</U>
ill add pics later
this isn't the actual picture but it looks like the same
ttt
eg cluster non tach
ek cluster non tach
b16 dist. obd I
jdm p30
b16 starter
b18b long block
ill add pics later
ttt
bakomack
Aug 7, 2009 09:31 AM
pro-driver22
Dec 12, 2007 05:38 PM
pro-driver22
May 27, 2007 05:27 PM
